Home > Technical > Front anti roll bar pipes |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 139 |
looks like 300 quid for a complete set |
Sat Jul 13 2019 4:52pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4319 |
I imagine they will be LR only parts... |
Sat Jul 13 2019 6:10pm |
[url]https://www.ebay.co.uk/itm/Range-Rover-Sport-front-ace-pipes-Range-Rover-Sport-arc-pipe-set-4-2-7-4-2-4-4/253727153951?epid=646585357&hash=item3b13511f1f:g:NykAAOSwhnlb7T6T
Sat Jul 13 2019 7:19pm |
Usually, vice grips on the pipes, and twist and lever out
Sat Jul 13 2019 7:42pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1047 |
Is it worthwhile replacing with copper ones? |
Sat Jul 13 2019 8:00pm |
just been watching on youtube a guy repairing one with a piece of copper,mine are pretty badly corroded all the way,so would probably just be easier to replace the whole lot.Now pretty much removed all mine ,except out of the valve block,sprayed wd40 all over it,try again tomorrow. |
Sat Jul 13 2019 8:09pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
Really don't think copper pipes is a good idea,
Sat Jul 13 2019 8:49pm |
Copper brake pipes have a burst pressure of around 400bar IIRC, but the constant pressure cycles do weaken the pipe over time
Sat Jul 13 2019 9:11pm |
Needs more volume than thin brake pipe, thicker copper pipe don't take as much pressure.
Sat Jul 13 2019 9:32pm |
[img]
Sun Jul 14 2019 4:00pm |
Now spare a thought for those of us who do this on a daily basis |
Sun Jul 14 2019 5:24pm |
Sun Jul 14 2019 5:39pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Have you seen my thread from last year?
Sun Jul 14 2019 10:32pm |
I clamped the valve block in the vice,took out the studs and tapped it of ,took a while.
Mon Jul 15 2019 4:21am |
