Home > Technical > Front anti roll bar pipes
daxmatt
Anybody know where i can get new pipes for this,its the front pipes on the off side,all gone rusty and leaking oil everywhere Crying or Very sad
Cheers all
its an 06 supercharged
Post #583934 Sat Jul 13 2019 5:32pm
daxmatt
looks like 300 quid for a complete set
Post #583937 Sat Jul 13 2019 5:52pm
Disco_Mikey
I imagine they will be LR only parts...
Post #583942 Sat Jul 13 2019 7:10pm
daxmatt
[url]https://www.ebay.co.uk/itm/Range-Rover-Sport-front-ace-pipes-Range-Rover-Sport-arc-pipe-set-4-2-7-4-2-4-4/253727153951?epid=646585357&hash=item3b13511f1f:g:NykAAOSwhnlb7T6T
Any tips on how to get the old ones of the valve block,they seem to be very stuck[/url]
Post #583945 Sat Jul 13 2019 8:19pm
Disco_Mikey
Usually, vice grips on the pipes, and twist and lever out
This entirely depends on how corroded the pipes are at the valve block, and whether they have enough strength remaining in the pipes to withstand being clamped in the jaws...
Post #583946 Sat Jul 13 2019 8:42pm
Pufftmw
Is it worthwhile replacing with copper ones?
Post #583948 Sat Jul 13 2019 9:00pm
daxmatt
just been watching on youtube a guy repairing one with a piece of copper,mine are pretty badly corroded all the way,so would probably just be easier to replace the whole lot.Now pretty much removed all mine ,except out of the valve block,sprayed wd40 all over it,try again tomorrow.
Post #583949 Sat Jul 13 2019 9:09pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Really don't think copper pipes is a good idea,
from the Manual: System pressure Variable between 3-165 bar dependant on lateral acceleration
Post #583951 Sat Jul 13 2019 9:49pm
Disco_Mikey
Copper brake pipes have a burst pressure of around 400bar IIRC, but the constant pressure cycles do weaken the pipe over time
Whether it would be a huge issue on the ARC system, I doubt it, but I certainly wouldn't attemp a repair with it
Fix it right 1st time, or don't fix it at all, IMO Thumbs Up
Post #583952 Sat Jul 13 2019 10:11pm
rover75
Needs more volume than thin brake pipe, thicker copper pipe don't take as much pressure.
when/if it does burst, it will be around a fast corner Shocked
you probably also consider the material hardness in places where rock collision is possible
as Disco_Mikey says Thumbs Up
Post #583953 Sat Jul 13 2019 10:32pm
daxmatt
[img]
Pipes removed , what a Censored getting the pipes out the valve block,[/img][img]
[/img]
Post #583984 Sun Jul 14 2019 5:00pm
Disco_Mikey
Now spare a thought for those of us who do this on a daily basis Laughing
Post #583987 Sun Jul 14 2019 6:24pm
daxmatt
Bow down Bow down
Post #583988 Sun Jul 14 2019 6:39pm
Brit Plumber
Have you seen my thread from last year?
https://www.rrsport.co.uk/forum/topic51144.html
To get the pipes out of the block, I used a steel trim removal tool and pried/levered the belled portion of the pipes out of the block. Car was 6 1/2 years old and they were all out in about 15 minutes. Very corroded especially around the rubber clamp mounts and ended up fitting new clamps.
Have you decided how you intend to fit the new pipes? 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
TPMS (Complete)
Genuine LR DRLs (Complete)
Remote Boot close from key fob (Complete)
2016 Discovery 4 Mirrors AKA RRS2 (Complete)
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE (Complete)
2014 LR4 Homelink (Complete)
2016 FFRR Electrochromatic Wing Mirror Glass (Complete)
67 plate Focus ST Line (Current)
Post #583996 Sun Jul 14 2019 11:32pm
daxmatt
I clamped the valve block in the vice,took out the studs and tapped it of ,took a while.
Ordering the pipes today,should be able to slide them back in,same way as removed,i took out the body mount rubbers on one side,gave me just enough room to slide out
Post #583997 Mon Jul 15 2019 5:21am
