![]() | Home > Technical > Front anti roll bar pipes |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 221 ![]() |
I,m changing the wishbones,so they will be out the way.
The issue I had was the mounting point, the gap between body and chassis was to small and no amount of manoeuvring would make them fit. Even taking the pipes out of the block fitting didn’t help.
I hope I don't ever have to do this - it looks like a pig of a job |
To be honest mate, I’ve done worse jobs. 2019 5.0 SC SVA (Current)
Did you have to lift the body? The gap looks a lot bigger than what I had available. 2019 5.0 SC SVA (Current)
lifted it about 40mm,just enough to get the rubber out |
Out of interest (he says, hoping never to have to do a job like this) - how involved is lifting the body (esp. just a "bit" like that)? Is it a "four bolts and it's done" kind of job or is it a "four bolts and 12987123 electrical connectors" job?
Its just a case of the body mount bolts on the drivers side,then jack it up slightly.
quick update,had a couple of warning lights come on dash(the body roll light),but went away after a few miles.
