Home > In Car Electronics > Centre display going blank whilst driving |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
our 13 MY has done exactly the same thing a couple of times - I'm none the wiser either as to how to fix I had some limp wristed crappy excuse about slow boot times on the screen but its clearly not that 2012 SDV6 HSE (technically its hers)
Thu Jul 11 2019 8:22am |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 180 |
Thanks Duc - by the way - do you know any good local specialists for this type of Land Rover electronics work as I see you are in Northants too? There is no replacement for displacement - W O Bentley
Thu Jul 11 2019 8:47am |
Loughren Brothers in Towcester for general stuff come highly recommended. Our local Landrover electrics guru is a chap called Alan Thrower - ALT Automotive. I'm also lead to believe that Bodsy who is the electrics guru of the Disco 3/4 forum has been known to make visits to Northampton in the past 2012 SDV6 HSE (technically its hers)
Thu Jul 11 2019 1:38pm |
Thank you for the tip on ALT Automotive. If the unit keeps powering down I'll give Alan a call as he's only 15 miles away.
Thu Jul 11 2019 7:12pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
If it helps, I have an intermittent fault with the display on my 2008 RRS. Just occasionally, on starting, instead of the normal display I get crazy lines like an old out of tune TV. Turning off and restarting does not help, but next time I start up in the course of a normal day's activity, its all back working OK! And, yes even with the crazy display, I still have radio, CD etc functions - just can't see 4x4 display or sat nav.
Fri Jul 12 2019 6:08am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
The reason the fault won’t clear straight away is that the entertainment system will only shut down after something like 10 minutes. Then it will reset. It sounds like the screen is being shutdown to protect the system. Have you checked for DTCs? 2012 5.0 SC AB
Sat Jul 13 2019 7:21am |
Need to find someone in Northamptonshire or Milton Keynes with a code reader There is no replacement for displacement - W O Bentley
Sat Jul 13 2019 1:15pm |
Had the codes read by dealer and nothing showing. Could it be the battery if on start up the drain on power for the starter is causing a 'wobble' (tech term) on the control system for the entertainment system? So far in the last month its only had this fault four times so its no biggy just a niggle ... unless it gets worse. Silverstone There is no replacement for displacement - W O Bentley MY2013 5.0 Supercharged HSE L320 |
Tue Aug 06 2019 10:59am |
In your first post you said it went blank when driving rather than on startup so a fading battery wouldn’t have that effect on it.
Wed Aug 07 2019 6:57am |
Sorry Brit Plumber - my explanation at the outset was not quite right. The unit fails to start (not even showing the usual 'Range Rover' logo) when I get in to start up. Have yet to check whether it has failed upon entry to the vehicle or after trying to crank the engine. I am now trying to be more observant each time I get in but it hasn't shown the fault since Friday.
Wed Aug 07 2019 7:23am |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Silverstone, I have had very good feedback about a small LR specialist garage in Rushden called RM Motors.
Wed Aug 07 2019 7:51am |
