Home > General > curiosity has ogt the better of me..... winch options |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
I'd check the numbers as it depends on whether the rating is achieved through motor or gearing
Wed Jun 12 2019 10:13am |
Sorry only just seen this! there are several options available.
Wed Jun 12 2019 12:04pm |
https://www.rrsport.co.uk/forum/topic48878.html?highlight=winch 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Wed Jun 12 2019 12:07pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Not 'plug-and-play', then!
Thu Jun 13 2019 7:52am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Quite a few times now - mainly pulling my tractor out of a muddy field |
Fri Jun 14 2019 7:24am |
Been used for recovery of others more than myself, but for me the main reason for fitting was for solo trips abroad, so i know I can get myself out of trouble should i need too. Also makes a good parking aid 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
Fri Jun 14 2019 12:46pm |
I'd agree with the winch being for others mainly. problem is seldom do you want to pull yourself forward , further into what you got stuck in.
Fri Jun 14 2019 4:08pm |
Any questions you have i will do my best to answer 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri Jun 14 2019 4:49pm |
Actually on a side topic Buckster, your RAI, did you have to modify it any to fit yours as its only listed as fitting up to 09 according to landrover 2012 SDV6 HSE (technically its hers)
Fri Jun 14 2019 5:06pm |
Yes modified to fit and sealed for waterproofing, but if your in that deep you are floating All modified just like everything else on a facelift car I did buy a brand new rear ladder but it was way to much aggro to modify it and I just didnt have the time so i gave up with that 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Wed Jun 26 2019 3:35pm |
don't suppose you have any details of the mods do you ? 2012 SDV6 HSE (technically its hers)
Wed Jun 26 2019 5:19pm |
I've just fitted an el cheapo RAI clone on my "classic" (i.e., pre-facelift) car, partly because a day on a dusty Salisbury Plain left the air-box absolutely full of (and because it looks 'cool').
Wed Jun 26 2019 5:25pm |
Similar thing to be honest. when in the Alps/Cevenne/Piedmont last year the RAI on the Disco saved me having to do a filter swap over the weeks we were away. 2012 SDV6 HSE (technically its hers)
Wed Jun 26 2019 5:54pm |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2834 |
our MY10 3 Litre oil burner with RAI (was sealed but since servicing assume it needs doing again),
Mon Jul 01 2019 8:10am |
