| RRSPORT.CO.UK | ||
|  | Home > In Car Electronics > Tesla Style Screen 10.4 - Project |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | Gerd1986,
|  Fri Mar 08 2019 8:49am |
| Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303      | I can't recommend this right now, I haven't done the facia as I'm having trouble with the unit which the seller can't seem to resolve:
|  Sun Mar 10 2019 11:20am |
| Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303      | Quick update on this:
|  Thu Apr 25 2019 1:22pm |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | have you had the trim pieces made yet ?
|  Thu Apr 25 2019 1:26pm |
| Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303      | I have someone that can make it for me from the LHD versions I have now, I'm just waiting until I'm happy with the unit first as it's expensive. I will PM you in a min. | ||
|  Thu Apr 25 2019 1:28pm |
| david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166      |
 Please do  I’ve much admiration for what your trying to achieve. | ||
|  Thu Apr 25 2019 1:53pm |
| Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303      | @david007 here you go, very quick video:
|  Fri May 03 2019 11:53am |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | Hay Gerd1986, did you put Timed Climate on your car or was it already installed? 2019 5.0 SC SVA (Current)
|  Sat May 04 2019 7:46am |
| Gerd1986 Member Since: 07 Oct 2015 Location: London Posts: 303      | It was already installed. | ||
|  Sat May 04 2019 12:54pm |
| david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166      | Wow, seriously impressed with what you’ve achieved   | ||
|  Sat May 04 2019 1:32pm |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | Gerd, Does it use the factory software interface for reverse cameras ? Also the parking sensors ? | ||
|  Tue May 07 2019 2:30pm |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849      | I think it just fits to the front of the FCDIM so it can still use (the system still needs it) software/most/gateway etc. The one thing I suspect it won’t do is work as a dual view as it won’t have the shutter technology installed. Although I think the CCF can be edited to display Tv on the move without any of the trick boxes you can buy. 2019 5.0 SC SVA (Current)
|  Tue May 07 2019 3:48pm |
 Bit of background to explain how it works.... The OEM unit comes in 2 parts, the screen which is attached to the 'processing unit' or 'computer' which tells it what to display. To install the tesla screen you separate the two, and detach the ribbon which connects the screen to the 'computer' , you the attach the ribbon to the tesla screen which provides the tesla unit with the OEM interface and screw the computer to the back of it. This means that you keep everything as it was before you installed the unit, the only difference is 'dual view' which I lost when installing this, although we never used it. I think this is the reason why the original interface you see on the tesla screen is off to the right, as it's picking up a signal that is off to the right to make dual view work, I'm planning on buying a 'single view' unit to try and correct this. By going into the 'control' menu on the unit you have access to the OEM interface and can use it in exactly the same way you would before installing the tesla unit. The tesla unit gets audio to the OEM unit via a headphone jack into the Aux connection at the back seats. As the OEM unit is still controlling all audio the parking sensor audio still works as normal. When you switch to Reverse the Tesla unit simply displays the OEM interface which had already switched to the rear view. The little car you see underneath can be removed in the settings and does not display any information as to how far you are away from anything around you. Hope this answers your questions. | ||
|  Wed May 08 2019 8:52am |
| mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270    | You answered my question in the last bit.
|  Wed May 08 2019 10:55am |
| Posting Rules
 , i would really like one just the lack of RHD panels put me off !
