![]() | Home > Maintenance & Modifications > Alive agent or alive headquarters? |
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 ![]() ![]() ![]() |
Is the default gear in ‘D’ wnd gear? Hence being slow when pulling out. I put mine in Sport and launch’s out of junction. I have no idea if it has been mapped.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Selecting Sport mode is my approach to busy junctions as well. I think that in standard drive, the car tends to select 2nd gear to start off in. Certainly seems to in the TDV8. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Alive are based in Louth in Lincs. They did my SDV6 2012 prob near 3 years ago. I visited their HQ. It was an ECU out job and took between 3 and 4 hours including test drive after.
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 426 ![]() ![]() |
So you have done 40k miles since having the map installed with no reliability issues, I'm sure I read on one of your other posts you had to replace both turbos, if that's correct what was the cause and was this on this car after having it mapped ?
The turbo issues were unconnected to the remap is the short answer, as many others who have had the same issue but not the remap would attest to. Similarly, an inlet manifold change is very common due to a crap original design and material spec. Nothing to do with the remap.
I've now decided I'm going to have it done at Alive headquarters but need to work out when I can get up to them as I'm down by Gatwick so not very local.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5152 ![]() ![]() ![]() |
If you only do 5k a year why not get a S/C, unlikely to get snapped crank and no chance of blown turbos |
Grizzly Member Since: 23 Nov 2018 Location: Hull Posts: 23 ![]() ![]() ![]() |
Before planning anything I would get in touch with Gary at Alive, he is the owner and main man. If you have some rough dates and he can guarantee to fit you in etc. He has a great reputation for well over a decade when it comes to anything with a green oval and diesel. The D2 forum I was on flocked around him in the original TD5 Alive days when he first got started He is an all round nice guy too, which helps |
I have no other issues with my car other than the hesitation pulling away from junctions and it took a long time to find the right spec and colour combo with the condition and low mileage my car has. Plus if I wanted a car with 500+bhp as my everyday sensible car I would be in a Audi RS6 and not a Range Rover. 2019 4.4 SDV8 Autobiography Velocity blue. 2017 SVR. SVO Scafell grey Ebony interior. Gone 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone |
Graham Ives Member Since: 04 Aug 2013 Location: Lincolnshire Posts: 74 ![]() ![]() ![]() |
I'm lucky and live in louth and thinking of having mine done turbos changed last month plus other bits and bobs plenty of B&Bs in and around louth mate Rrs sport 2012 Orkney grey |
