![]() | Home > Technical > IID Tool - what settings did you add/change? |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
This exactly what I was looking for thank you! Not pretending to know anything about electrics I’m guessing the switch you installed was an inline switch on the patch lead? What switch do I need to get and any pictures of yours... |
That's right Buster. It's a single switch that switches both patch leads. It's a double pole switch so it's effectively two switches controlled by a single button. The switch I used was from Amazon, they come in a pack of 10 for £1.70....
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
could you explain for others what you have done there.
I assume the fuse box in question is the PASSENGER COMPARTMENT FUSE BOX and not the engine bay fuse box?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
If you have simply bridged fuse 24 & 49 together as well as 50 & 29 with a switch between the two pairs which disconnects the ignition live feeds from 49 & 50 I understand that, but still not sure what happens when you turn the headlights etc. on in normal use as would this not give a power back feed to the circuits as I thought in my earlier reply. As said not auto electrician so abit unsure. Only if you have to change the new switch position each time would it not be easier just to switch sidelights on every time you start the car?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
The only thing I changed with the IID was turning off auto wipers. It meant that the intermittent wipe worked as an intermittent with the rate selectable on the column. I hate auto wipers. 2012 SDV6 - it's missing a couple of cylinders
Yes, this is the interior fusebox behind the glovebox. All headlight functionality remains the same.
Got it now, does seem easier way than cutting into harness,would have thought after a few months if there were any return feed issues it would have showed up by now. |
Does the glove box come out for easy access? Cheers Laurence. |
What happens if you try to leave parking lights on ?? |
To get to the passenger compartment fusebox, you simply push both support stays inwards. The glovebox then hinges down into the footwell.
Xrover Member Since: 08 Feb 2018 Location: Palm Desert Posts: 31 ![]() ![]() ![]() |
I have definitely got my money’s worth from my IID Tool.
Baz0195 Member Since: 29 Jun 2018 Location: Telford Posts: 23 ![]() ![]() ![]() |
Hi xrover. Do you have a list of what changes/modifications you can do on a 2010 mate. |
Go on the GAP website and look up your vehicle to see what all you can do with
