Home > Technical > IID Tool - what settings did you add/change?
Page 3 of 3 <123
Xrover
United States 2008 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Baz0195 wrote:
Hi xrover. Do you have a list of what changes/modifications you can do on a 2010 mate. Question
or anyone else that can help Thumbs Up
Go on the GAP website and look up your vehicle to see what all you can do with
https://www.gap-diagnostic.com/products/iidtool/ 2006 LR3 HSE
2008 RRS HSE
Post #577262 Sun Mar 17 2019 7:40pm
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Cheers xrover Thumbs Up
Post #577273 Sun Mar 17 2019 10:22pm
Kouze59
France 2010 Range Rover Sport TDV8 HSE Santorini Black
knwatkins wrote:
That's right Buster. It's a single switch that switches both patch leads. It's a double pole switch so it's effectively two switches controlled by a single button. The switch I used was from Amazon, they come in a pack of 10 for £1.70....
https://www.amazon.co.uk/gp/product/B00IID...&psc=1
I used some 'add a circuit' fuse holders from the internet, however, it's very tight to fit them in and not ideal for access to other fuses once installed. If I did it again, I would use the fuse with a breakout wire from Halfords...
https://www.halfords.com/workshop-tools/ga...amp-hfs280
I've just nipped out to the vehicle to take some pictures for you. Unfortunately, it's not clear to see so I have taken some pictures of the fuse box printout I used to guide me when doing the mod with the fuses highlighted....
Fuse 49 > Fuse 24
Fuse 50 > Fuse 25
Hope this helps!
Hello, thank you for this mod. I have just installed it in my L320 and it works. As space is limited, I tried to use a single fuse, the 24, connected to the 49/50. This also works. Could this be a problem? I've also tried to find a fuse that is active after the ignition is switched on or after the engine is started, does anyone know of one? Thanks in advance
Post #634693 Mon Jul 31 2023 3:32pm
Page 3 of 3 <123
