![]() | Home > General (L494) > ACC / Disabling "follow mode"? |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1198 ![]() ![]() ![]() |
I didn't think the follow mode could be disabled. Mine's a MY15, but will try it tomorrow on the highway and report back. --
harisson Member Since: 28 Jun 2018 Location: CH Posts: 185 ![]() ![]() |
Thank you naks |
No problem.
Yes should be so. If you push the increase button, the acc should be reactivated.
Ok, I drove 50km to the physio and 50km back home, most of it on the highway, and I can report that this method does NOT disable the ACC.
Thanks naks!
I am pushing up this topic..
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9081 ![]() ![]() ![]() |
I do know that you can disable ACC and just have CC on the original RRS using an IID Tool or similar to change the Car Configuration File (CCF). Assuming LR still use CCFs, it might be worth seeing if your dealer, or an independent LR specialist, can alter the CCF for you. 2012 SDV6 - it's missing a couple of cylinders
Thanks for the answer
Even back in 2005 this was a problem with JLR’s ACC, I had it on my 2007 TDv8 and in winter the sensor in the front bumper would get slush/snow on it on the motorway and once the message “sensor blocked” flashed on the dash there was no cruise control at all, not even conventional non-adaptive. It seems that the JLR ostrich still has its head firmly stuck in the sand 12 years later....... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
That issue with snow-covered acc radar I didn't have
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 ![]() ![]() |
I've got ACC but unfortunately I'm nowhere near my car to see if I can disable follow mode. it's not CC but ISL might be an alternative? Ferrari F430 Spider F1
Doesn’t it now work off the centre roof consul.?if so put a sticker on the outside of the screen & see if that works. Andy.
Tyrefitter.. sorry, which screen you mean? As fahr as I know the radar is under the front plate.. Range Rover Sport HST D350 |
