Home > Faults & Fixes > Central locking life of its own when keys out the ignition
XSPRS
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
Just stopped at home and turned the car off, with the key still in but off the hazards come on and the central locking locks and unlocks. Also had the heater fan puffing at the same rate as the hazards.... very odd.
It also threw up a parking brake issue but that went away and also HDC when i pulled off earlier.
Is it a low battery? throwing up faults or water ingress somewhere.
I have disconnected the battery for the moment as couldn't do anything else.
Any help would be good.
Its a 2005 with 31k on the clock had it around 6 months now. with no issues pervious.
Thanks
Jason
Post #571850 Fri Dec 28 2018 4:20pm
XSPRS
Anyone ?
If I let it have a fit it does stop after around a minute.
One thing to add is I understand the RRS is sensitive to battery voltage. Over the last few weeks I have had the low battery warning come up on the radio panel. But no other symptoms to report. Sometimes I might suspect a lazy start but no issues.
Would a low battery cause the central locking to throw a fit when ignition off ?
Post #571966 Sun Dec 30 2018 9:22am
TubaPlayer
Low batteries can do all sorts of strange electrical things, worth trying a decent charger on the battery and maybe even a recon setting on the charger. 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #571992 Sun Dec 30 2018 5:26pm
XSPRS
Well i checked the battery and it was 11.6 v this morning so took the punt and purchased another this morning. And its not cleared the issue.
It does however turn over and start a little better. When driving the car drives lovely no issues what so ever.
Stop the car and the car automatically goes to unlock all the doors, as soon as it does that the hazards come on and it just repeats itself unlocking every 2-3 seconds in tune with the flashers.
What i did notice was the drivers door would not always lock when pressing the key fob...
Could i have a faulty door latch/lock ? and its just telling me.
Post #571994 Sun Dec 30 2018 6:02pm
Brit Plumber
I assume you have the auto lock feature enabled? If so, try disabling it for a while and see what happens. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572008 Sun Dec 30 2018 8:17pm
XSPRS
Thanks for the suggestion - it was activated now disabled but with no change...
Rolling Eyes
Post #572054 Mon Dec 31 2018 11:33am
XSPRS
Not sure if the link will work but you can see exactly what she is doing here.
Post #572064 Mon Dec 31 2018 12:09pm
Brit Plumber
Try opening all the doors, boot and bonnet before turning the engine off and see what that does. If it doesn’t fail at that point I’d try closing the doors, boot and bonnet one at a time, starting and stoping the engine in between to see if that does anything. 2019 5.0 SC SVA (Current)
Post #572087 Mon Dec 31 2018 4:02pm
XSPRS
Well now we're getting somewhere. Opened all doors and the hazards flashed once. Nothing else. I closed all doors one by one and nothing until I closed the front passenger door when it did it just a few times then stopped. I closed all doors and it was back to square one.
So with this point to the 2 fronts what does it tell me ? Faulty door actuators ??
Thanks again
Post #572099 Mon Dec 31 2018 6:26pm
XSPRS
Well i might have jumped the gun a little. Having thought i was getting somewhere i just tried it again the same procedure and it had no affect at all.
Going to pull the central locking fuse in a bit see what that does.
Big Cry
Post #572153 Tue Jan 01 2019 3:45pm
Brit Plumber
It may be worth googling Range Rover Sport Body Control Module faults.
http://www.bba-reman.com/gb/content/range_...e_problems
The link suggests checking the fuse box for corrosion first before suspecting the BCM. The link is for the FFRR and Disco but the sport has suffered the same issues.
Do you have a sun roof? Noticed any damp patches? Pressure washed the car recently? 2019 5.0 SC SVA (Current)
Post #572192 Wed Jan 02 2019 10:15am
XSPRS
Hmmm.
Funny you should mention the pressure washer as i washed it but the pressure washer was playing up so i used a hose pipe on full force!! where is the BCM located.
I checked the fuse box under the bonnet and all seemed fine there.
Yes have a sunroof but not actually looked for any damp will investigate further today.
again thankyou.
Post #572198 Wed Jan 02 2019 10:59am
Brit Plumber
Have a read here, sounds very similar
http://www.rrsport.co.uk/forum/topic42765.html 2019 5.0 SC SVA (Current)
Post #572202 Wed Jan 02 2019 12:17pm
XSPRS
Drivers side footwell soaked !!! rubber mat had hidden it
Post #572207 Wed Jan 02 2019 1:23pm
Brit Plumber
Sounds like we have a symptom for the problem. But you need to identify the initial issue. Do you have a sunroof? If so, it’s common for the drains to block, lots of posts on the forum about it. Then it’s possible water has got on to some of the wiring/instrument cluster/ECUs.
Hopefully fixing the leak and drying out the cabin will fix it, but the damage maybe done. 2019 5.0 SC SVA (Current)
Post #572208 Wed Jan 02 2019 1:34pm
