![]() | Home > Faults & Fixes > Central locking life of its own when keys out the ignition |
XSPRS Member Since: 08 Oct 2018 Location: N Wales Posts: 20 ![]() ![]() ![]() |
Anyone ?
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
Low batteries can do all sorts of strange electrical things, worth trying a decent charger on the battery and maybe even a recon setting on the charger. 2016 Black SDV8 Autobiography
Well i checked the battery and it was 11.6 v this morning so took the punt and purchased another this morning. And its not cleared the issue.
I assume you have the auto lock feature enabled? If so, try disabling it for a while and see what happens. 2019 5.0 SC SVA (Current)
Thanks for the suggestion - it was activated now disabled but with no change...
Not sure if the link will work but you can see exactly what she is doing here.
Try opening all the doors, boot and bonnet before turning the engine off and see what that does. If it doesn’t fail at that point I’d try closing the doors, boot and bonnet one at a time, starting and stoping the engine in between to see if that does anything. 2019 5.0 SC SVA (Current)
Well now we're getting somewhere. Opened all doors and the hazards flashed once. Nothing else. I closed all doors one by one and nothing until I closed the front passenger door when it did it just a few times then stopped. I closed all doors and it was back to square one.
Well i might have jumped the gun a little. Having thought i was getting somewhere i just tried it again the same procedure and it had no affect at all.
It may be worth googling Range Rover Sport Body Control Module faults.
Hmmm.
Have a read here, sounds very similar
Drivers side footwell soaked !!! rubber mat had hidden it |
Sounds like we have a symptom for the problem. But you need to identify the initial issue. Do you have a sunroof? If so, it’s common for the drains to block, lots of posts on the forum about it. Then it’s possible water has got on to some of the wiring/instrument cluster/ECUs.
