Home > Faults & Fixes > Central locking life of its own when keys out the ignition |
XSPRS Member Since: 08 Oct 2018 Location: N Wales Posts: 20 |
Both drain holes were plugged with crap and not draining properly.
Wed Jan 02 2019 3:22pm |
I hope it just takes a good drying to sort. Keep an eye on the sunroof drains as I know a lot of posts on here comment on replacing them. I get the impression that they can deteriorate quite rapidly. 2012 5.0 SC AB
Wed Jan 02 2019 3:25pm |
Where is the exact location of the BCM ? is it behind the fuse board under the glove box. |
Wed Jan 02 2019 7:02pm |
I actually don’t know but have seen threads intimating that is in that area or possibly the main fuse box. I’ve also read that an issue with the instrument cluster can give similar symptoms as the low speed can bus is connected to it. As you mentioned the drivers footwell being damp, it may be worth a check in that area. 2012 5.0 SC AB
Wed Jan 02 2019 7:09pm |
Well looks like I dodged a bullet.
Thu Jan 03 2019 8:22pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
Finger Crossed 2016 Black SDV8 Autobiography
Thu Jan 03 2019 8:24pm |
Passenger footwell makes sense then. Water in the fuse box/BCM then. Keep checking after heavy rain and keeping the sunroof drains clear should cure it for good.
Thu Jan 03 2019 8:36pm |
Yes worthy of a change I think.
Thu Jan 03 2019 10:25pm |
cheet Member Since: 06 May 2013 Location: Nuneaton Posts: 6 |
I have had the same problem. Central locking having a mind of its own, various faults flashing up on the dash display.
Wed Apr 03 2019 8:18pm |
Wed Apr 03 2019 8:19pm |
