![]() | Home > General (L494) > Crankshaft issue,manufacturers & extended warranty confu |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
You are being lied to
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
I would not buy it unless you get it in writing that the KNOWN crank issue is covered. This is exactly the reason I now drive a BMW after 20 years of Landrover ownership. |
And yes I agree , you are being lied to ........ |
I agree too,they are lying,I sold a my14 ab sdv6 WITH only 33000miles flrsh 12 months approved warranty remaining on car,the chap who bought the car for good money as it had warranty had it 2 weeks & the crankshaft failed & LR would not fix/repair under the approved warranty & told the customer it’s £18500 plus vat for a new engine.Please don’t listen to anything those salesmen tell you,& for the bit were they say they haven’t heard of the issue then they are probably lying again as it’s even been in some of the car mags & national papers.
As others have said above, you are being lied to on 3 accounts: a) extended warranty being the same as LR/manufacturer warranty; b) extended warranty covering the crank issue; and c) salesman and service guys being unaware of the issue, unless ALL of them are new to the brand.
There is another issue that you need to be aware of and that is the oil dilution issue with Sd4 and SDv6 engines, again due to a design fault. Not every car suffers with it BUT if your car needs to do a lot of DPF regenerations and the dash indicator shows more frequent serving than is acceptable then you have the issue too.
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Are the oil dilution and crankshaft issues related?
Yes, you will have manufacturer’s warranty until May ‘19. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 ![]() ![]() ![]() |
Tim - what engines are they stopping ? SDV6 & SDV8 ? Where did the 5ltr petrol come from? |
The Ford PSA based engines will all be replaced with Ingenium motors - straight sixes for the SDv6 replacement. This isn’t new news, it’s been known for several years since JLR opened its own engine plant near Coventry.
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
It's a 5 year service pack, not a 5 year warranty pack. You'll get 2 years warranty from the point you buy it, made up of the original warranty to 3 years post original purchase, plus used-approved for the rest. The 5 year service pack covers the first 5 services - either annually or at 16,000 mile intervals.
