![]() | Home > Technical > Removable Towball setup |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
Tim,
This is a different setup to the one I had on the TD6. There I had the removable drop plate hook and then I modified that to utilise my Freelander bike carrier - I now see that LR use the Freelander bike carrier modified in the same way as I did mine for all the ranges too! Now I've sold the bike I no longer need the drop plate type hook which is whay I went for the removable swan neck type - it can be stowed inside the boot unlike my modifed drop plate job from the RR.
NeilR Member Since: 21 Jun 2005 Location: wakefield/West Yorkshire Posts: 246 ![]() ![]() ![]() |
Hi
Simon Member Since: 13 Jun 2005 Posts: 44 ![]() ![]() |
I have a Discovery 3 as well and was pleased to get a free tow bar on the RRS. Ok, it has not got the electrics, but for an occasional bit of shunting around the yard, it's fine; provided of course that the tow hook has been kept on neutral ground!
Robbi Member Since: 14 Jun 2005 Location: Channel Islands, Guernsey Posts: 130 ![]() ![]() ![]() |
Tim,
Mine was dealer fitted. I was chatting to a D3 owner at the All Rover Rally in Newcastle this weekend and he says that they all leave the factory with the electric socket (I asked for single electric and got a white and a black socket) fitted as well as all the gear underneath the car, all the dealer has to do is connect up the electrics and sell you the towhook................. but I find this hard to believe! Anyone who has not specified the tow bar care to open the removeable section of rear bumper and post a pic of what they have hiding in there? There should be dual electrics and a massive recovery eye behind the plastic plate. |
BN Member Since: 10 Jul 2005 Location: Northamptonshire Posts: 58 ![]() ![]() |
One problem is that stupid electrics cover. I have had two new screws made with little turnbuckles built into the heads for easy removal of the plastic cover, what a boon. |
tasmod Member Since: 07 Aug 2005 Location: NE Lincs Posts: 396 ![]() ![]() ![]() |
The tow setup was ordered as a factory fit on my car. (TDV6 HSE Rimini Red)
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2589 ![]() ![]() ![]() |
I have ordered the factory fit removable tow bar assembly on mine. It is costing me £400, and they said if I wanted it afterwards it would cost me £900 for the dealer to fit it all.(That's why I ordered it)
Hi
Spoke to the parts dept at Sturgess here in Leics and they say that it does seem that you can buy the removable tow hook on it's own for £200 plus VAT and just plug it into any RRS.
RRUK,
I think I have managed to answer my own question and reckon it's probably for the best to stick with the factory fit order, afterall, whenever I come to sell the car it might not look good to only have half the kit fitted. L319 D4 HSE
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
It's an old topic but still actual for me and it proves I can use the search! |
