Home > Technical > Removable Towball setup
Page 2 of 3 <123>
Tim in Scotland
McB in the UK we have several companies who will fit an aftermarket tow kit to any make of car, including Land Rovers, usually they use good equipment and can fit for a fraction of the dealer price. There is a national chain of fitters here called Indespension who also sell trailers as well. Have a look in your local Yellow Pages or on Yell.com
under caravan sales or trailer sales. The only thing that can cause a problem is the wiring of the electrics which will require the trailer lighting indicator in the instument binnacle to be enabled. BTW I have suffered (and know of several others who have also had the problem) of the red plastic insert for the removable tow hook receiver falling out. On my last RRS I ended up putting silicone sealant on it to keep it in place when I wasn't towing! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #232895 Fri Aug 07 2009 8:48am
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Thanks for the fast answer. Only problem: I'm not in the UK. In Germany we have aftermarket-companies, too, but they are not really cheaper than LR. However my biggest problem is not the fitting (that will cost about 100€ at LR stealer) it is to buy the correct parts. Since usually the users here know a lot more than the local LR dealers I'd like to ask here which parts to buy!
My point is: Which wiring kit and which tow bar do I have to buy where in the UK (online please)?
(Shipping to Germany won't be a big problem, costs just a few Euros. Due to sum of LRs there are much more dealers for stuff like that in UK than in D and due to the exchange rates they are also much cheaper.)
Thanks!
And thanks for the tip with the red plastic thing. In my case I think I will use gaffa tape which I always have with me since the army-days. Mr. Green RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #232898 Fri Aug 07 2009 9:16am
MAW
Those two links appear misleading - it claims manufacturer =LR then list towbar make as Thule / Brink. From the pic it is not the OEM part....
Post #232901 Fri Aug 07 2009 9:23am
MAW
http://cgi.ebay.co.uk/DISCOVERY-3-RANGE-RO...286.c0.m14
This is the towbar you want - £50 - £300, the electrics can be found the same way for around £80 normally....
Post #232902 Fri Aug 07 2009 9:26am
MAW
http://cgi.ebay.co.uk/Land-Rover-Discovery...286.c0.m14
Here is one with electrics
Post #232903 Fri Aug 07 2009 9:28am
McBunny
Thanks a lot, that's excactly what I'm looking for! Very Happy Bow down
The thing that I didn't like about my two links was the Thule, I know them from roof boxes for various Mercedes models and there is a really big quality difference between the originals and the Thule-ones. With the originals we drove more than 200 km/h (ca. 125 mph), the Thule-Stuff already started shaking and moving at 130km/h (80 mph)... That's why I asked, I thought it might be they are the same, so thanks a lot for your links! Thumbs Up
As I said I'll pull 3.5 tons and therefore I want to be sure to have the best stuff I can get to do so... Smile RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #232908 Fri Aug 07 2009 9:34am
MAW
You are welcome Very Happy
FYI re the electrics - there was a shortage recently as I beleive the supplier went under but there was talk of someone else stepping in (as they'd have to).... IIRC you'll see two configurations of electrics a single and double socket set referred to as N & S IIRC.... search on here though and you'll find plenty on the subject Thumbs Up
Post #232913 Fri Aug 07 2009 10:01am
Killerbob
Switzerland 2009 Range Rover Sport TDV8 HSE Java Black
Hi McBunny,
Watch out with buying non-original parts in Germany! In Switzerland the STVA (Strassenverkehrs- und Schifffahrtsamt) are incredibly anal when it comes to approving non-factory fitted tow-balls. The require a check for the paperwork to be in order, and I had an after-market tow-ball fitted to my Lexus RX300 three years ago, and it wasn't approved the first, or the second time. I ended up paying more than I would have for a Lexus dealer fitted tow-ball, and all of that with no warranty. The Lexus one is very very expensive (>SFR.1'500/GBP750), so I thought I could save a bit and go for a good offer from a camper dealer - but no.
I think the same rules apply in Germany, they are anal as well, so watch out.
KB RRS TDV8, black with ivory.
Post #232917 Fri Aug 07 2009 10:09am
McBunny
You're right, in Germany all this is very strict. Another reason to buy a tow bar with "LandRover" on it. Due to the fact that a factory fitted towbar will not apear in any of the car's papers nobody will be able to tell it is aftermarket, therefore no need for an entry in the papers if it is a genuine-part! Cool RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #232921 Fri Aug 07 2009 10:14am
dazsear
I fitted my own electrics (£80 from eBay) and providing you get the correct LR product for the RRS its a doddle to do. The electrics come complete with full replacement looms/gromets and amazing instructions to make the job easy for most people. I think my tow bar cost £150 (again from eBay).
One thing to consider is the ecu programming.....to do the job properly this needs to be done to cancel out the fog lights and possibly the reverse sensors when the trailer is attached.
I've not bothered doing this and cant say it has ever been an issue since I only tow small trailers and would want the fog lights to work with my trailer anyway.
Daz 2017 4.4 Autobiography FFRR - love this car
Gone - VW T5 Transporter
Long gone - 2009 Disco
Long gone but never out of my thoughts - 2008 TDV8 HST
Post #232933 Fri Aug 07 2009 10:54am
MAW
Thumbs Up Reversing sensors get 'cancelled' by the trailers presence through the electrics - ECU mod is fogs only and I agree with you Daz
Post #232959 Fri Aug 07 2009 3:05pm
zoo
I purchased a bar off ebay but the retaining pin only engages in the aperture approx 5mm - the key locks and removes all ok. Does this seem correct?
It's a lot of weight on such a small area of metal. Appreciate any comments
Post #236861 Tue Sep 15 2009 10:35pm
MAW
I cannot recall how far the pin engages as i tend to leave it on most of the time now..... handy if you get a rear end shunt as once happened to me..... I do recall thinking similar, there is a lot of load relying on a little - but i guess the load is against the 'vertical' faces in the horizontal plane ......
If the key is out sounds like you'll be OK - IIRC the key only comes out when engaged Thumbs Up
Post #236874 Wed Sep 16 2009 7:29am
zoo
thanks for the prompt reply MAW - and reassurance! You're right about the vertical loading.
Just managed to pick up a used trailer and I was imagining the worst as I turned a corner with full load of logs onboard.
This is my first forage into 4x4 ownership and so far, I'm loving it. Thanks again.
Post #236923 Wed Sep 16 2009 10:41am
samd
Just a note of caution. I had removeable fitted and it appears that they forget to programme the 'computer' to tell it that the electrics were fitted. Only thing that worked was fog light came on on caravan when side lights turned on on RRS. Apparently can't get the wiring wrong as is all plug and play! Going back this afto - hopefully sorted.
[Later] Cobblers - they put a 2010 wiring loom in instead of 08/09
Post #238540 Wed Sep 30 2009 10:10am
Page 2 of 3 <123>
