![]() | Home > Technical > Tyre pressure? |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I`m running my 22`s at 37 f and 40 r mate. Steve. |
Left4dead Member Since: 03 Feb 2018 Location: Newcastle Posts: 7 ![]() ![]() ![]() |
Do yours look like this? I have to inch up kerbs etc as they go totally flat when put up against something, I’m just worried about putting more pressure in. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
I keep 40psi in mine,,,, but try to avoid driving up kerbs, you will certainly damage your wheels at some point 2010 RRS, TDV8
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
I drive up anything I choose but then I have proper tyres on mine... |
I’ve actually only been over one kerb and took it really slowly but I could feel that it rolled on the rim (through the tyre). I’ve owned an X5 previously with low profiles on but the tyre wall still stood straight with 38-40psi. I’m beginning to wonder if it’s the walls of the tyres that have maybe been ran low before I bought it and now they won’t stand up? Cheers for the reply’s though lads. |
The X5 was probably designed for low profile tyres, the RRS certainly wasn't - 40% or 50% aspect ratio was what LR specified for your vehicle. It could also just be that the tyre isn't really suitable for the RRS. I know people run that tyre but maybe better options are out there? 2012 SDV6 - it's missing a couple of cylinders
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1917 ![]() ![]() |
But the X5 was probably a run flat tyre with stiffer side walls? 2026 P460e Autobiography on order
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
mine look a bit like that too, and I run less than 40psi for comfort over speed bumps |
Yeah mine as similar looking. Don`t drive up kerbs so can`t comment on that. Steve. |
Cheers for the help lads, it sounds like it’s normal from the comments. I’m new to the RRS but have had numerous cars, 4x4s etc throughout my life and these just looked like they were lacking in pressure but now that I’ve had a few people running similar saying that theirs are the same I’m happier with them. Btw the X5 tyres weren’t run flats. |
I didn`t even notice when mine were around the 16psi mark recently |
