Home > Maintenance & Modifications > Running board removal
Jit
2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
One of my running boards on my L320 has seen better days so I’m going to replace the pair. Given that all of the mounting hardware is already there, is this just a case of removing the old board and putting the new one on?
Also how do the boards come off? I’m led to believe they slide off away from the car? Would I need to remove the lower moulding to remove?
Any help is much appreciated
Post #545218 Mon Jan 08 2018 7:52pm
PEACHY
There are 3 brackets per side & each board is secured to each bracket with 2 nylon locknuts. Remove the locknuts & the boards will slide off - they made need some persuading if they are old - rusty etc. The fitting is the reverse - again you may need to give them a little help if they don't line up straight away. If your just replacing the boards the trim & everything else stays attached to the Sport - good luck Thumbs Up 16MY Estoril Blue SVR.............
Post #545230 Mon Jan 08 2018 8:45pm
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
If you look on powefuluk website, they have 2 step by step videos of how to install them MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #545332 Tue Jan 09 2018 7:58pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Yes it’s straight forward unbolt then pull/slide off and push on with replacements, mine were rotten through so ended up just knocking them off with a lump hammer and the rust just fell off. Give the bolts and guides a good wd40 spray before hand.
http://www.rrsport.co.uk/forum/topic49086.html
Post #545353 Tue Jan 09 2018 10:50pm
Jit
Thanks guys. Will be tackling the task today! Fingers crossed all the bolts come off nice and easy
Post #545377 Wed Jan 10 2018 8:23am
Eaters
...and some copper grease on the new bolts you put in. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #545480 Wed Jan 10 2018 10:58pm
