Home > General > Sidestep trim end caps?
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Anyone know if it is possible to buy replacement end caps for the aluminium trims for the 2009 L320.?
Got mine back today, the ones I bought from a member on here. They were in good condition but rather than have them slowly corrode away like the ones currently fitted have done. I stripped them down, had them sand blasted, hot dip galvanised and when I picked them up I then gave them 3 coats of zinc primer, topped off with 3 coats of black gloss. And yes to please many of you Thumbs Up I had the trims powder coated gloss red again. Mr. Green Only, they misplaced the end caps hence why the post in the first place, I may have 1 or 2 on my set but would rather buy new if possible.
As they came back
First coat of zinc primer
Then a coat of gloss black
Genuine Land Rover stamps
Post #538221 Fri Oct 13 2017 5:35pm
Cymruambyth
Wales
Do you mean these?
http://www.ebay.co.uk/itm/EDGE-STRIP-KIT-T...2149323858 Steve.
Post #538229 Fri Oct 13 2017 6:06pm
Danv8
Just the 4 black bits. But thanks ile email him see if he will sell a set separately.
Post #538246 Sat Oct 14 2017 7:13am
Danv8
Got around to fitting them today, a few bolts so badly rusted had to be ground off, but other than that a simple but slightly long winded job. I can’t believe the state of the ones I removed.
Considering at the most these can only be Max 8 years old.
Near side, side step put back together.
Driver side, I only use it to push myself in not actually baring my weight on it, thank god!
But passenger side, and my wife does step on it fully as she’s a short ass.
Post #538289 Sat Oct 14 2017 10:20pm
Johnski
Genuine new Side Step End Cap available from Land Rover Parts Departments, but they are very expensive at £40.14 each inc VAT. Part No: STC7562 Big Cry John
Post #538290 Sat Oct 14 2017 11:06pm
John, That's a very old part number I'm inclined to think they maybe for the old P38. Thumbs Up
Post #538291 Sun Oct 15 2017 12:57am
adameverett
Top job Thumbs Up you would hope they will see your ownership out! I like the galvanised idea rather than just undercoating up, approx what did you spend on blasting/galvanising.
Post #538295 Sun Oct 15 2017 7:08am
Cymruambyth
Wales
Looks very smart....especially the red against the white Thumbs Up Steve.
Post #538304 Sun Oct 15 2017 10:52am
Danv8
Blasting of the 6 brackets and 2 boards and alu trims was £38, galvanising of the boards and brackets were £106 and the powder coating the alu was £50.
I got the steps from a local guy on here for £125 so all in was about £320. For a better than new set of genuine landrover steps. All fixings were replaced with new stainless bolts etc.
All done be at BMT, Great Yarmouth
Actually gave the car a clean so all looking fresh again
I DO HAVE IF ANYONE IS INTERESTED A SET OF CUT PLASTIC GENUINE LANDROVER SILLS AND RUBBER TREADS. THAT CAME WITH THEM, BUT I ALREADY HAD THEM ON MINE. FREE TO WHO EVER WANTS TO COLLECT THEM.
Post #538339 Sun Oct 15 2017 3:54pm
Cymruambyth
Wales
Nice...love the alloys Thumbs Up Steve.
Post #538341 Sun Oct 15 2017 4:16pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Excellent idea to get the steps and brackets galvanised, I've still not fitted any to mine as the corrosion after a short while was of concern. This is definately now on my to do list.
But for anyone planning doing the same, skip the galvafroid, it's not needed and may cause additional problems as most paints will react with it, it needs a particular type paint after, which I cannot remember which just now. Also, as the metal is already galvanised then galvafroid is pointless, just keep moisture away from the galvanising and it'll last almost forever, just T-wash or equivalent then paint with appropriate paints.
Here's a good link for galvanised finishes. http://www.galvanizing.org.uk/painting-galvanized-steel/ 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #538349 Sun Oct 15 2017 4:36pm
Danv8
Yep was unnecessary but i asked the guys about spraying it and this is what they said, and it wasn’t any more expensive than normal primer, It purely personal choice as I was worried that if the rubber mats didn’t seat correctly of the red trims didn’t marry up flush the shiney silver finish may of been seen and I didnt want that. Would of just hammerited it, but I couldn’t find a brush.lol
Post #538354 Sun Oct 15 2017 5:02pm
