![]() | Home > Maintenance & Modifications > Running board removal |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
There are 3 brackets per side & each board is secured to each bracket with 2 nylon locknuts. Remove the locknuts & the boards will slide off - they made need some persuading if they are old - rusty etc. The fitting is the reverse - again you may need to give them a little help if they don't line up straight away. If your just replacing the boards the trim & everything else stays attached to the Sport - good luck |
| Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197
If you look on powefuluk website, they have 2 step by step videos of how to install them MY 13 3.0 SDV6 HSE Black Edition
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378
Yes it’s straight forward unbolt then pull/slide off and push on with replacements, mine were rotten through so ended up just knocking them off with a lump hammer and the rust just fell off. Give the bolts and guides a good wd40 spray before hand.
| Jit Member Since: 03 Dec 2015 Location: London Posts: 43
Thanks guys. Will be tackling the task today! Fingers crossed all the bolts come off nice and easy |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1562
...and some copper grease on the new bolts you put in. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
| All times are GMT |
