Home > General > Suspension fault vehicle lean when cornering
Supercharged lad
United Kingdom 2005 Range Rover Sport Supercharged Autobiography Java Black
Good evening every body
The rrs is driving perfectly and doesn't feel any different than normal but the light saying suspension fault vehicle lean when cornering lights up every time I switch on as of yesterday Sad it came on first time when the vehicle was stationary but running any ideas on what I should do cheers
Post #458238 Sat Apr 04 2015 8:59pm
PEACHY
Does access & extended mode still work - try whilst stationary - see if there is a noisy compressor it's positioned under the RRS in front of the rear passenger side rear wheel. It's strange it's highlighted on start up without any other obvious faults Crying or Very sad
I have tried calling Thumbs Up 16MY Estoril Blue SVR.............
Post #458242 Sat Apr 04 2015 9:19pm
Supercharged lad
Hi there mate I'm at my mums with my i pad car at home will have a go at all your suggestions tommorow thanks for getting intouch hope all is well your end Thumbs Up
Post #458244 Sat Apr 04 2015 9:28pm
PEACHY
Car ?????
Evil or Very Mad
That's worse than JEEP !!!
Rolling with laughter Rolling with laughter Rolling with laughter
Take care Thumbs Up 16MY Estoril Blue SVR.............
Post #458245 Sat Apr 04 2015 9:30pm
Supercharged lad
I'm staying for tea and a couple of beers Laughing so don't risk my pride and joy Thumbs Up
Post #458248 Sat Apr 04 2015 9:37pm
nil07
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
Hi All
i have same problem in my 2 week old car
2015 model started car and RED warning came up saying SUSPENSION FAULT...
called receovery and they said fine to drive and take it to dealer next day.
next day all was fine for about 20 mins then the FAULTY VEHICLE LEAN orange sign came up - drives fine though
car currently with JLR - awaiting news.
really frustrating how a brand new car has developed this.
any ideas anyone? is this minor electrical thing ? wiring issue? seeing that everything else sounds normal.
thoughts welcome
am so gutted
Post #458323 Sun Apr 05 2015 7:12pm
nil07
just been told by grange barnet that theres a suspension pipe thats cracked and its leaking fluid so they have to order that in.
anyone had this experience?
Post #458667 Thu Apr 09 2015 10:18am
Ferret15
United Kingdom 2008 Range Rover Sport TDV8 HSE Sumatra Black
Would like to bump this post again if possible.
The wife just called me on the school run and had a message come up with orange light saying. Suspension fault vehicle lean when cornering. She said the car was driving fine. This happened as soon as she pulled out of the drive. (Our drive pulls out on a really steep hill).
Turned on and off and everything fine. Does anyone have any advice?
I have notice the compressor is quit noisy when you turn the car on and then stops once level is set. I will try extending it and lowering it later to see if any faults come up.
In the meantime what could I look into it being?
08 3.6 TDV8
Thanks all
Post #535429 Fri Sep 15 2017 8:16am
Ferret15
Update: did about 50miles yesterday and the fault did not happen again. Did see a few people report a similar problem which acures a couple times a year with not problems actually evolving.
So is anyone able to tell me how noisy the compressor is meant to be? Mine is pretty loud.
Post #535568 Sat Sep 16 2017 10:33am
PEACHY
In my experience compressor failure is a gradual process - mine took a few months to fail completely Big Cry I would describe the noise as a bag of ball bearings rattling not deafening but certainly noticeable Thumbs Up 16MY Estoril Blue SVR.............
Post #535569 Sat Sep 16 2017 10:44am
It's probably an issue with the Dynamic Response system (hydraulic anti roll bars). Check the level in the reservoir - it's the one behind the driver's side headlight. 2012 SDV6 - it's missing a couple of cylinders
Post #535571 Sat Sep 16 2017 10:57am
DrRob
FYI - there is a mobile mechanic and site sponsor called Woody32 in Taunton. Look him up Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #535575 Sat Sep 16 2017 11:34am
DerrekL
Did you get rid of the Suspension fault vehicle lean when cornering message?
I have this same issue for a number of weeks now and cannot for the life of me get to the bottom of what is causing it. The central locking switches on, hazards flashing constantly, radio, heaters switch off, then everything just switches back on whenever it feels like it.
I have checked all the usual suspects, brake light switch, bulbs, battery etc;etc; but the issue seems to go away for a while then reappears. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #554396 Tue Apr 17 2018 12:41pm
PC76
dragged up from the depths Rolling with laughter
do you have active suspension? if so you will have a yellow top bottle to the left hand side of the radiator. check the level of the fluid is above minimum...
Post #554511 Wed Apr 18 2018 5:37pm
DerrekL
Yes indeed... Thumbs Up
Fluid is at the correct level. I was going to have a closer look at the air suspension control module. I believe this is situated on drivers side bolted at about knee level., does that sound about right?
Yes this is a nightmare of a problem, all seems OK one minute with no lights at all on the dash then I hear the dreaded doors locking and the hazards go mental, not good for the nerves Big Cry RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #554581 Thu Apr 19 2018 11:23am
