Home > General > Suspension fault vehicle lean when cornering |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Does access & extended mode still work - try whilst stationary - see if there is a noisy compressor it's positioned under the RRS in front of the rear passenger side rear wheel. It's strange it's highlighted on start up without any other obvious faults
Sat Apr 04 2015 9:19pm |
Supercharged lad Member Since: 13 Jul 2014 Location: Cheshire Posts: 44 |
Hi there mate I'm at my mums with my i pad car at home will have a go at all your suggestions tommorow thanks for getting intouch hope all is well your end |
Sat Apr 04 2015 9:28pm |
Car ?????
Sat Apr 04 2015 9:30pm |
I'm staying for tea and a couple of beers so don't risk my pride and joy |
Sat Apr 04 2015 9:37pm |
nil07 Member Since: 05 Apr 2015 Location: london Posts: 115 |
Hi All
Sun Apr 05 2015 7:12pm |
just been told by grange barnet that theres a suspension pipe thats cracked and its leaking fluid so they have to order that in.
Thu Apr 09 2015 10:18am |
Ferret15 Member Since: 11 Jun 2017 Location: Somerset Posts: 31 |
Would like to bump this post again if possible.
Fri Sep 15 2017 8:16am |
Update: did about 50miles yesterday and the fault did not happen again. Did see a few people report a similar problem which acures a couple times a year with not problems actually evolving.
Sat Sep 16 2017 10:33am |
In my experience compressor failure is a gradual process - mine took a few months to fail completely I would describe the noise as a bag of ball bearings rattling not deafening but certainly noticeable 16MY Estoril Blue SVR.............
Sat Sep 16 2017 10:44am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8856 |
It's probably an issue with the Dynamic Response system (hydraulic anti roll bars). Check the level in the reservoir - it's the one behind the driver's side headlight. 2012 SDV6 - it's missing a couple of cylinders
Sat Sep 16 2017 10:57am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
FYI - there is a mobile mechanic and site sponsor called Woody32 in Taunton. Look him up Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Sat Sep 16 2017 11:34am |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Did you get rid of the Suspension fault vehicle lean when cornering message?
Tue Apr 17 2018 12:41pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 387 |
dragged up from the depths
Wed Apr 18 2018 5:37pm |
Yes indeed...
Thu Apr 19 2018 11:23am |
