![]() | Home > General > Suspension fault vehicle lean when cornering |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Does access & extended mode still work - try whilst stationary - see if there is a noisy compressor it's positioned under the RRS in front of the rear passenger side rear wheel. It's strange it's highlighted on start up without any other obvious faults |
Supercharged lad Member Since: 13 Jul 2014 Location: Cheshire Posts: 44 ![]() ![]() ![]() |
Hi there mate I'm at my mums with my i pad car at home will have a go at all your suggestions tommorow thanks for getting intouch hope all is well your end |
Car ?????
I'm staying for tea and a couple of beers |
nil07 Member Since: 05 Apr 2015 Location: london Posts: 115 ![]() ![]() ![]() |
Hi All
just been told by grange barnet that theres a suspension pipe thats cracked and its leaking fluid so they have to order that in.
Ferret15 Member Since: 11 Jun 2017 Location: Somerset Posts: 31 ![]() ![]() ![]() |
Would like to bump this post again if possible.
Update: did about 50miles yesterday and the fault did not happen again. Did see a few people report a similar problem which acures a couple times a year with not problems actually evolving.
In my experience compressor failure is a gradual process - mine took a few months to fail completely |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9097 ![]() ![]() ![]() |
It's probably an issue with the Dynamic Response system (hydraulic anti roll bars). Check the level in the reservoir - it's the one behind the driver's side headlight. 2012 SDV6 - it's missing a couple of cylinders
FYI - there is a mobile mechanic and site sponsor called Woody32 in Taunton. Look him up ![]() * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Did you get rid of the Suspension fault vehicle lean when cornering message?
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
dragged up from the depths |
Yes indeed... |
