Home > General > Engine top end strip down
Page 9 of 13 <123 ... 8910 111213>
DerrekL
I'm assuming the cam bearing caps are lettered for LH side. If that's the case then who I bought heads off have mixed one of the numbered caps from the RH side.
Should the RH side be numbered and LH side lettered?
On the LH side I am currently working on as the two end caps can only go on one way I was using that as a guide.
I appreciate the bearing caps should only go on the way they came out the factory but the joys of buying second hand. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #535389 Thu Sep 14 2017 8:51pm
The manual indicates the positions.
Post #535393 Thu Sep 14 2017 9:23pm
DerrekL
I've scanned through the workshop manual and do see plenty of detail regarding the camshaft fitting, torque etc; but not the level of detail I need about bearing cap numbers, letters, location sequence. If you have the the manual and can let me know the page number that would be grand. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #535410 Thu Sep 14 2017 10:20pm
DerrekL
I do see in the LR workshop manual reference to letters A to I and R to Z
...however the heads I bought have numbers and letters, I assume one bank numbers and letters for other bank.
I did find this online (picture attached) of a C6 engine and it refers to numbers and letters also. Which makes me think the heads I have bought are off a C6 as the guy was selling them as off a RRS, I maybe wrong here but just a thought, thoughts?
P38 4.6 HSE V8
Post #535422 Fri Sep 15 2017 7:23am
garrycol
Australia
I have had a look at the relevant section of the topix manual - the sequence seems pretty straight forward and I don't see that diagram you have posted.
What workshop manual are you using - topix seems straight forward if missing a little detail for amateur mechanics.
garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #535432 Fri Sep 15 2017 8:31am
Disco_Mikey
One bank is numbered, one bank is lettered.
Heads are likely to be identical between D3/4, RRS and PSA applications
Post #535435 Fri Sep 15 2017 8:35am
Disco_Mikey
garry
From the Citroen workshop manual Thumbs Up
Post #535436 Fri Sep 15 2017 8:35am
DerrekL
garry
Thanks garrycol, the picture I attached in earlier post is an extract from the C6 Citroen manual. Can you send me a link to the topix manual. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #535440 Fri Sep 15 2017 9:07am
DerrekL
Good stuff DM that's the kind of thing I was hoping to hear. RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #535441 Fri Sep 15 2017 9:08am
garrycol
Australia
garry
Its on Topix so you will need to buy a subscription and download it (or at least the sections you need) - it is the LR genuine information. https://topix.landrover.jlrext.com/topix/ 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #535445 Fri Sep 15 2017 11:02am
does seam that the Citroen manual is better.
It also has torque values for the bottom end too, which the LR one doesn't IIRC.
Post #535447 Fri Sep 15 2017 11:36am
DerrekL
garrycol wrote:
garry
Cheers garrycol RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #535451 Fri Sep 15 2017 11:51am
DerrekL
Thanks Andy, yes glad I found this online as was bit worried when the bearing caps not in sequence when heads arrived. Anyways hopefully get a bit further now the weekend is nearly here. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #535452 Fri Sep 15 2017 11:53am
Disco_Mikey
And that in itself would worry me enough not to use it Thumbs Up
Post #535455 Fri Sep 15 2017 12:50pm
DerrekL
Andy K wrote:
Check all the threaded holes are clear. Wind bolts in all the way.
In particular the belt tensioner hole at back and fuel rail mount.
So much easier to find you have an issue now rather than later.
Make sure the bracket for the water pipe is fitted at the back.
Clean engine face off to ensure clean.
Put head on with exhaust studs, gasket and green thing which I think helps keep gasket from falling off.
Check everything is aligned.
Put head bolts in as tighten as per sequence.
You can put a bit of wire into the chain tensioner to keep in together
Put clean oil into a jar and put the hydraulic lifters in one by one and pump them to draw in oil.
Fit to head.
Note the chain has 2 red links. This is to allign with cams square cuts outs to ensure it's timed correctly.
If the cam wheels are still fitted with cover you need to get them and chain back into the head.
Get the chain tensioner in between chain and fitted the correct way round so the oil hole in aligned.
The cam brackets must match the head it came from.
They are engraved with numbers to show their position. Refer to manual.
Fit bolts hand tight. Ensure you are happy with timing and red chain links still by cut outs.
The clamps by the wheels have some glue under it to seal it (as per eBay link)
Rotate cams a small amount to ensure they move freely.
Get rear belt and cover sorted. Fun!
With this it's aways worth checking things are alligned and getting bolts half in to ensure the sequence is possible and things alligned.
Before fitting cam cover for the last time ensure chain tension pin is removed , the rear fuel pipe is loosly fitted and pour a bit of fresh oil over cams
Tighten exhaust manifold and don't forget heat shield before egrs!
Rear egr pipe is bigger than front so the blanks don't fit Sad Sad
Got most of this list checked off at the weekend. Feels like I'm getting somewhere... eventually.
Regarding the EGR valve for the LH side, does this actually have to go back onto the car? I can't just blank the exhaust manifold and pipework off? RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #535741 Mon Sep 18 2017 10:58am
