Check all the threaded holes are clear. Wind bolts in all the way.
In particular the belt tensioner hole at back and fuel rail mount.
So much easier to find you have an issue now rather than later.
Make sure the bracket for the water pipe is fitted at the back.
Clean engine face off to ensure clean.
Put head on with exhaust studs, gasket and green thing which I think helps keep gasket from falling off.
Check everything is aligned.
Put head bolts in as tighten as per sequence.
You can put a bit of wire into the chain tensioner to keep in together
Put clean oil into a jar and put the hydraulic lifters in one by one and pump them to draw in oil.
Fit to head.
Note the chain has 2 red links. This is to allign with cams square cuts outs to ensure it's timed correctly.
If the cam wheels are still fitted with cover you need to get them and chain back into the head.
Get the chain tensioner in between chain and fitted the correct way round so the oil hole in aligned.
The cam brackets must match the head it came from.
They are engraved with numbers to show their position. Refer to manual.
Fit bolts hand tight. Ensure you are happy with timing and red chain links still by cut outs.
The clamps by the wheels have some glue under it to seal it (as per eBay link)
Rotate cams a small amount to ensure they move freely.
Get rear belt and cover sorted. Fun!
With this it's aways worth checking things are alligned and getting bolts half in to ensure the sequence is possible and things alligned.
Before fitting cam cover for the last time ensure chain tension pin is removed , the rear fuel pipe is loosly fitted and pour a bit of fresh oil over cams
Tighten exhaust manifold and don't forget heat shield before egrs!
Rear egr pipe is bigger than front so the blanks don't fit
