| RRSPORT.CO.UK | ||
|  | Home > Technical > Servo |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      | How does it get past the valve   | ||
|  Mon May 29 2017 5:55pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Apparently its a bit of a nightmare if you get air into the ABS block. But I guess with an IID you can sort it. | ||
|  Wed May 31 2017 8:39pm |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      | I I D Andy ? | ||
|  Wed May 31 2017 8:47pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | IID = A diagnostic tool; to open valves in the ABS module to release air.
|  Wed May 31 2017 9:31pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      |
 Completely normal   As long as the pedal is rock solid when the engine is off, it's fine | ||
|  Thu Jun 01 2017 4:33am |
|  Thu Jun 01 2017 5:59am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | The servo provides assistance to the braking system. It's also checked as part of the MOT
|  Thu Jun 01 2017 6:06am |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      | Well thanks mate , that makes me happier   | ||
|  Thu Jun 01 2017 6:09am |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      | I'm still not sorted and slowly loosing the will to live   | ||
|  Thu Jun 01 2017 6:45pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Did you disconnect the pipes from the master cylinder then?
|  Thu Jun 01 2017 6:59pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | http://www.disco3.co.uk/forum/topic52130.html
|  Thu Jun 01 2017 7:01pm |
 No Andy , from the block and I did try to prop it | ||
|  Thu Jun 01 2017 7:36pm |
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145      | Thanks Andy I've had a look through Bodsy s bible but I can't find anything other than references to T4 but doesn't say what to do?
|  Thu Jun 01 2017 7:55pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | It does sound like it needs a trip to the dealer.
|  Thu Jun 01 2017 8:35pm |
| Posting Rules
 really Mikey , didn't do that before, unless the engine oil in it was a factor
