![]() | Home > Technical > Servo |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
How does it get past the valve |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
Apparently its a bit of a nightmare if you get air into the ABS block. But I guess with an IID you can sort it. |
I I D Andy ? |
IID = A diagnostic tool; to open valves in the ABS module to release air.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Completely normal ![]() As long as the pedal is rock solid when the engine is off, it's fine |
The servo provides assistance to the braking system. It's also checked as part of the MOT
Well thanks mate , that makes me happier |
I'm still not sorted and slowly loosing the will to live |
Did you disconnect the pipes from the master cylinder then?
http://www.disco3.co.uk/forum/topic52130.html
No Andy , from the block and I did try to prop it |
Thanks Andy I've had a look through Bodsy s bible but I can't find anything other than references to T4 but doesn't say what to do?
It does sound like it needs a trip to the dealer.
