Home > Technical > Servo
Page 2 of 3 <123>
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
How does it get past the valve Confused
Post #527065 Mon May 29 2017 6:55pm
m3nutter
Need a bit of help please,
I can't get a good pedal , hard pedal with engine off but when you start it the pedal decays nearly to the floor. If you let it up the next is better and if you pump again better still.
I've bled fronts but not rears yet..
Air leak between master cylinder and servo ?
Post #527282 Wed May 31 2017 9:36pm
Apparently its a bit of a nightmare if you get air into the ABS block. But I guess with an IID you can sort it.
Post #527283 Wed May 31 2017 9:39pm
m3nutter
I I D Andy ?
Post #527285 Wed May 31 2017 9:47pm
IID = A diagnostic tool; to open valves in the ABS module to release air.
Not sure if the IID can do it actually.
Dealer can.
Look at the brake bible on here or www.disco3.co.uk
Post #527291 Wed May 31 2017 10:31pm
Disco_Mikey
Completely normal Thumbs Up
As long as the pedal is rock solid when the engine is off, it's fine
Post #527315 Thu Jun 01 2017 5:33am
m3nutter
Shocked really Mikey , didn't do that before, unless the engine oil in it was a factor Laughing
I will bleed everything again today in any case Thumbs Up
Post #527317 Thu Jun 01 2017 6:59am
Disco_Mikey
The servo provides assistance to the braking system. It's also checked as part of the MOT
Comleptely normal, and more exaggerated with the Brembo-equipped servo Thumbs Up
Post #527318 Thu Jun 01 2017 7:06am
m3nutter
Well thanks mate , that makes me happier Thumbs Up
Post #527319 Thu Jun 01 2017 7:09am
m3nutter
I'm still not sorted and slowly loosing the will to live Laughing
I've bled at each calliper using mrs m3 at the pedal hoping it would improve but if anything it's worse .
Symptoms now are pedal goes to floor with engine off
But if you pump it you get a pedal that is good and doesn't decay
Start it and pedal goes to floor
Then next pump is good
However, road test brakes are good but first push is very low pedal but second pump is normal pedal
Rolling Eyes
Any help would be appreciated
I haven't tampered with the module except to connect master cylinder
Only bled at wheels
Post #527377 Thu Jun 01 2017 7:45pm
Did you disconnect the pipes from the master cylinder then?
I would have pulled it away from the servo and propped it on something. (all very easy to say now)
Post #527380 Thu Jun 01 2017 7:59pm
http://www.disco3.co.uk/forum/topic52130.html
Page 33
http://media.disco3.co.uk/gallery/albums/u...ssPics.pdf
Other stuff
http://www.disco3.co.uk/wiki/Maintenance
Post #527381 Thu Jun 01 2017 8:01pm
m3nutter
No Andy , from the block and I did try to prop it
Post #527383 Thu Jun 01 2017 8:36pm
m3nutter
Thanks Andy I've had a look through Bodsy s bible but I can't find anything other than references to T4 but doesn't say what to do?
Am I coming up a dead end on how to bleed this block do you reckon?
Post #527384 Thu Jun 01 2017 8:55pm
It does sound like it needs a trip to the dealer.
See if they can sort the oil issue and you may have to pay for the bleeding.
I guess you don't admit to much. Just say brakes are very bad and oil found in servo
Post #527385 Thu Jun 01 2017 9:35pm
Page 2 of 3 <123>
