![]() | Home > Technical > Servo |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
No you can see much from under the car.
| m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145
Cheers Andy ,
You can't see the pipes from under the car. |
Not even with a neck like ET ?
Get the top engine cover off.
Thanks Andy |
What actually happens here. It seems a sudden stab at the pedal is fine but holding a light pedal looses pressure from servo ?
Are the servos all the same, looking to replace and the ref numbers are different but the descriptions say they will fit?
You could put a white cable tie into the servo to see if there are sights of oil.
They will all physically fit and are interchangeable. However, if you have non-Brembo calipers, you can upgrade to the stronger Brembo equipped servo |
Ah ok thanks Mike and Andy
is there enough vacuum off the inlet manifold to work this servo? or not on tick over revs?
Well would you believe it, there's more in here than in the sump!
well at least you know why now |
| All times are GMT |
