Home > Technical > Servo
Page 1 of 3 123>
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Servo
im getting occasional lack of power assistance from the servo, happens infrequently but needless to say it happens!
it looks like its had the none return valve and dual pipe fitted but I am trying to get through to LR to get the recall confirmed.
my question is though, if I raise it to off road height it will do the same occasionally as if the pipe is stressed and then leaks or the pump is lacking in pressure.
is the pump and pipe at the back of the engine, drivers side, and can you see it from underneath with guard off?
thanks Neutral
Post #526840 Fri May 26 2017 2:47pm
No you can see much from under the car.
Well just the back of it but you can't do anything useful from under the car.
Post #526844 Fri May 26 2017 5:09pm
m3nutter
Cheers Andy ,
I suppose even seeing it may help, I just want to see the pipes are not snagged and on right
Post #526847 Fri May 26 2017 5:23pm
You can't see the pipes from under the car.
Post #526855 Fri May 26 2017 6:49pm
m3nutter
Not even with a neck like ET ?
Very Happy
Post #526857 Fri May 26 2017 7:01pm
Get the top engine cover off.
Lower suspension
Get a torch
And you can see them under the bonnet st the back
Post #526861 Fri May 26 2017 7:52pm
m3nutter
Thanks Andy
Post #526869 Fri May 26 2017 10:02pm
m3nutter
What actually happens here. It seems a sudden stab at the pedal is fine but holding a light pedal looses pressure from servo ?
Do I need to change servo or pump or both ?
Post #526893 Sat May 27 2017 10:29am
m3nutter
Are the servos all the same, looking to replace and the ref numbers are different but the descriptions say they will fit?
Mines a tdv6 2.7 rrs ?
Anyone know ?
Post #526912 Sat May 27 2017 5:10pm
You could put a white cable tie into the servo to see if there are sights of oil.
If they are try and gets the dealer to sort it
Post #526914 Sat May 27 2017 5:22pm
Disco_Mikey
Anyone know ?
They will all physically fit and are interchangeable. However, if you have non-Brembo calipers, you can upgrade to the stronger Brembo equipped servo Thumbs Up
Post #526917 Sat May 27 2017 5:37pm
m3nutter
Ah ok thanks Mike and Andy
It has got brmbos on - might take the tube out tomo and see if there's anything in it
Post #526921 Sat May 27 2017 6:54pm
m3nutter
is there enough vacuum off the inlet manifold to work this servo? or not on tick over revs?
just an idea Rolling Eyes
Post #526977 Sun May 28 2017 1:46pm
m3nutter
Well would you believe it, there's more in here than in the sump!
Post #527040 Mon May 29 2017 11:27am
well at least you know why now
Post #527049 Mon May 29 2017 1:17pm
Page 1 of 3 123>
