![]() | Home > Maintenance & Modifications > When should i change the Cam Belt? |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
Unfortunately I cannot say I am surprised. I have learnt so much from the members on this forum which is usually the case when you buy a car |
Lhard92 Member Since: 31 Dec 2020 Location: Bristol Posts: 21 ![]() ![]() ![]() |
Hello chaps - resurface of this thread. Looking through SH on my RRS Autobipgrahy 3.0 2011....
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
no it doesn't drive from the cambelt.
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 184 ![]() ![]() ![]() |
No it doesn't drive the water pump. If its not broke don't fix it. L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
Hi Liam,
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi yes as stated best getting it done my RRS 3.0 v6 2013 62000 goes in on Monday next week class b service and transfer box oil change and gearbox oil filter change anyone a tenner they can lend me lol . |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
The rear belt dives the high pressure fuel pump which supplies fuel to common rail. On the 3.0 it is timed (something to do with creating pulses to level out the pressure as the injectors open?). As in the 2.7 the engine would just stop if it broke, but I have no idea if replacemnt becomes problematic on the 3.0. I understand when changing the rear belt on the 3.0 there is locking pin that has to be used, I guess to preserve that timing.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
I had Disco-Mikey do a service, cambelts, g/box flush & transfer box oil change a couple of months ago. Car, 6 years old only done 12000miles & a lot of people would be |
apparently if the fuel belt goes it can take out the wiring loom.
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 274 ![]() ![]() |
The auxiliary belt on my last Volvo let go and took out the cam belt and consequently the cylinder head. A lot of damage for a £20 bit of rubber. Change it if its old, no guarantee it wont fail, but at least you know you did the right thing. RRS HSE Dynamic SDV6 2014
