![]() | Home > General (L494) > Slow puncher |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
As most decent vehicles have TPMS you will be aware if the slow leak starts again. Biggest issue I think is when a Tyre is run flat and then repaired with one of these, inside damage unseen may lead to a deadly failure. If I had nearly worn out tyres and had the OP's slow leak I would do on car repair and run until tyre replacement only on the rear. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Triple7 Member Since: 27 Oct 2011 Location: Wiltshire Posts: 154 ![]() ![]() |
On the subject of punctures, what tyre pressures are peeps running.
I didn't trust PDI which is why I checked tyre pressures as soon as I brought the car home from dealership on day 1. All 4 were 50+ psi which explained the less comfortable ride home |
I run 36 38 but since this car is not equipped with TPMS it could be anything between checks. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9122 ![]() ![]() ![]() |
6 months? Wow. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
TPMS! |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
TPMS is for people too daft to appreciate the benefits of accurate tyre pressures. Like the dashboard oil checker, which is for people who never would have checked the oil anyway. And still won`t.
Actually TPMS is very good when you have a puncture whilst driving, it notifies you before you notice the tyre going down. I have it on my motorcycle and this has been very good for getting to a garage before the tyre is flat and enabling me to do a repair and then use the garage air supply. When researching the TPMS you will notice the reason why they are mandatory is due to safety I read somewhere that under inflated tyres caused a great number of accidents.
How accurate is sufficiently accurate for you? My TPMS shows exactly the same pressures as my digital air compressor (rounded to whole numbers). Good enough for me as I very much doubt fractions of a psi matter. No other way for owners to check oil except on the dash of newer RRS (both L320 and L494) but then again I have always found it makes sense, for example shows full to the top just after a service. As long as it is within the 'OK' range it's fine. I did have a failed oil level sensor in my previous Sport but it reported a sensible fault rather than simply displaying incorrect information. When that happens, you just get it fixed. It doesn't try to fool you into believing all is good when it isn't. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
I've checked the accuracy of the TPMS and it's very good, very happy it's on my RRS. 2017 MY17 SDV6 SE |
I don`t disagree with any of the comments above. My point is that responsible owners would be checking their tyre pressures anyway. Doing, so gives you the opportunity to spot damage to the tyres too. Never looking at the tyres does not. TPMS is a legal requirement in Europe now in any case.
Agreed that oil level check in the instrument panel, while accurate, is a pain. In addition to being quick, dipstick also gives you some idea about the condition of the oil. Then again, the service indictor probably takes that into account. We got way off topic with this one though |
Yes we did. I had better stop there. |
