Home > General (L494) > Slow puncher
andymc
Slow puncher
Inevitably, I have ended up with a slow puncher. got a low pressure warning this morning so added about 10 PSI and checked the grooves. found a large nail stuck in there.
checked out some pricing for the 295/40/22's (ContiContact5) and got a bit is a surprise - then after a few second felt even worse thinking that I might get coerced into replacing a pair!
So my question is - what is the recommendations on replacing 1 tyre ? (car only has 8k miles on it and all the tyres look to have loads of tread left.) SVR with a few bits from Urban and Glohh
Post #523449 Wed Apr 12 2017 7:41pm
Tyrefitter
Get the puncture repaired.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #523452 Wed Apr 12 2017 7:54pm
Tyrefitter
The conti 5's aren't cheap that size,that's what I'm running on my 22's.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #523453 Wed Apr 12 2017 7:56pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Get it repaired. Reminds me - I've a screw in one of mine that needs repairing before they go back on.
Post #523455 Wed Apr 12 2017 8:08pm
wilf
So long as the nail/screw is at least 1" away from the edge of the tread/sidewall, a repair should be fine.
My spare has one. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #523462 Wed Apr 12 2017 8:41pm
IRBails
Australia
Re: Slow puncher
This is a simple repair and since you own an off road vehicle should be one you learn to do. I had the same issue on a rear tyre and it took me about 15 mins to fix using a plug . I would not run the tyre on the front for added safety. As your tyrs are near replacement run untill they need replacement. These types of punctures are common and the fix is very easy. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #523474 Wed Apr 12 2017 10:14pm
HemoRRS
No real offence intended but you own an SVR so one would assume your slightly older and in a good job.
Yet you can't differentiate between puncher and puncture. Laughing
I won't even get started on the lumpy idol thread...
Post #523559 Thu Apr 13 2017 4:42pm
syl
My spare has one.
And even if you can't have a minor repair as above, you can still send the tyre away for a major (hot vulcanised) repair, rather than buy a brand new pair of tyres.
Post #523572 Thu Apr 13 2017 8:24pm
andymc
HemoRRS wrote:
No real offence intended but you own an SVR so one would assume your slightly older and in a good job. Yet you can't differentiate between puncher and puncture.
*you're SVR with a few bits from Urban and Glohh
Post #523573 Thu Apr 13 2017 8:28pm
HemoRRS
I'll give you that one! Rolling with laughter
Post #523579 Thu Apr 13 2017 9:23pm
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
Maybe a professional boxer!!!! 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #523588 Fri Apr 14 2017 12:26am
andymc
puncture repaired today at a grand price of 25GBP - woohoo! SVR with a few bits from Urban and Glohh
Post #523655 Fri Apr 14 2017 11:59pm
IRBails
Australia
50 time the price of DIY. . worth getting a plug kit for next time, might be you can't get to the garage when you are out in the bush or it is Good Friday and everything is closed.
this is a fix if the tire has not been driven flat and is a temp measure for rear tires , Riding a motorbike I am often having to fix tires in the bush and have got this down to an easy job. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #523658 Sat Apr 15 2017 1:05am
andymc
The only Bush my SVR is going near is the one planted in my front garden.
took the local professionals about 30 minutes to do the job. Not sure I could get the wheel off in 5 minutes let alone finish the job in that time. SVR with a few bits from Urban and Glohh
Post #523661 Sat Apr 15 2017 1:35am
Tyrefitter
Those type plugs are only for temporary use in the uk,,Ive used them before but I wouldn't like to think I was running round in a 2 ton plus car with one in.Ive used them on truck tyres just to get them home or to nearest tyre depot.I also use them in lawnmower tyres as they don't do over 10mph.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #523665 Sat Apr 15 2017 7:32am
