Home > General (L494) > Slow puncher
wilf
I have one of these repair kits, they have saved my bacon more than once, good for a "get you home" repair, and actually they will stand up to some speed. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #523716 Sat Apr 15 2017 6:03pm
IRBails
Australia
Tyrefitter wrote:
IRBails wrote:
50 time the price of DIY. . worth getting a plug kit for next time, might be you can't get to the garage when you are out in the bush or it is Good Friday and everything is closed.
this is a fix if the tire has not been driven flat and is a temp measure for rear tires , Riding a motorbike I am often having to fix tires in the bush and have got this down to an easy job.
Those type plugs are only for temporary use in the uk,,Ive used them before but I wouldn't like to think I was running round in a 2 ton plus car with one in.Ive used them on truck tyres just to get them home or to nearest tyre depot.I also use them in lawnmower tyres as they don't do over 10mph.
Andy.
As most decent vehicles have TPMS you will be aware if the slow leak starts again. Biggest issue I think is when a Tyre is run flat and then repaired with one of these, inside damage unseen may lead to a deadly failure. If I had nearly worn out tyres and had the OP's slow leak I would do on car repair and run until tyre replacement only on the rear. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #523749 Sat Apr 15 2017 11:41pm
Triple7
On the subject of punctures, what tyre pressures are peeps running.
The pressure placard tells me 34psi at the front and 37psi at the rear.
After 6 months I decided to check and found the fronts were 40psi and the rears 37.. pdi my arse..... Gone:
2016.5MY RRS HSE Dyn
2015MY Disco Sport HSE
2011MY FL2 HSE
2010MY RRS HSE
2008MY D3 HSE
Post #523811 Sun Apr 16 2017 6:42pm
fkarim
I didn't trust PDI which is why I checked tyre pressures as soon as I brought the car home from dealership on day 1. All 4 were 50+ psi which explained the less comfortable ride home Shocked Brought down to the recommended pressures (34 and 37). Worth doing a wheel alignment check as well. Mine was OK when done a week after collecting the car but you never know. While we're talking about PDI, headlight beams were also set too high and were dazzling oncoming vehicles' drivers. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #523824 Sun Apr 16 2017 8:34pm
IRBails
Australia
I run 36 38 but since this car is not equipped with TPMS it could be anything between checks. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #523832 Sun Apr 16 2017 10:34pm
6 months? Wow. 2012 SDV6 - it's missing a couple of cylinders
Post #523847 Mon Apr 17 2017 11:54am
Triple7
TPMS! Whistle Gone:
2011MY FL2 HSE
2010MY RRS HSE
2008MY D3 HSE
Post #524040 Wed Apr 19 2017 9:50pm
Black Bess
TPMS is for people too daft to appreciate the benefits of accurate tyre pressures. Like the dashboard oil checker, which is for people who never would have checked the oil anyway. And still won`t.
The RRSport is a heavy car and is better with the tyres kept pretty firm. I run 40 psi all round. It takes the vagueness out of the steering and helps the tyres to wear nice and square. 34psi is too soft on the front end. LR only do that to avoid criticism of harsh ride.
If I were towing more regularly than I do, I would run 50psi in the rear.
Try it at 40psi. It works! The TPMS won`t notice anyway, but you can set it to the 'heavy load' setting if you like.
Post #524059 Thu Apr 20 2017 11:02am
IRBails
Australia
Actually TPMS is very good when you have a puncture whilst driving, it notifies you before you notice the tyre going down. I have it on my motorcycle and this has been very good for getting to a garage before the tyre is flat and enabling me to do a repair and then use the garage air supply. When researching the TPMS you will notice the reason why they are mandatory is due to safety I read somewhere that under inflated tyres caused a great number of accidents.
I do agree manually checking Tyre Pressure and Oil Level is a good habit , I hate the auto oil as the only source of checking level , RR electronics are known for failure. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #524107 Thu Apr 20 2017 10:29pm
fkarim
How accurate is sufficiently accurate for you? My TPMS shows exactly the same pressures as my digital air compressor (rounded to whole numbers). Good enough for me as I very much doubt fractions of a psi matter.
No other way for owners to check oil except on the dash of newer RRS (both L320 and L494) but then again I have always found it makes sense, for example shows full to the top just after a service. As long as it is within the 'OK' range it's fine. I did have a failed oil level sensor in my previous Sport but it reported a sensible fault rather than simply displaying incorrect information. When that happens, you just get it fixed. It doesn't try to fool you into believing all is good when it isn't. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #524110 Fri Apr 21 2017 12:09am
matsoutback
Australia
I've checked the accuracy of the TPMS and it's very good, very happy it's on my RRS. 2017 MY17 SDV6 SE
Post #524121 Fri Apr 21 2017 7:16am
Black Bess
I don`t disagree with any of the comments above. My point is that responsible owners would be checking their tyre pressures anyway. Doing, so gives you the opportunity to spot damage to the tyres too. Never looking at the tyres does not. TPMS is a legal requirement in Europe now in any case.
As for the electronic oil checking; it takes me about 20 seconds to lift the bonnet and dip the oil. With the dashboard system, you have to warm the engine, then switch off and wait 10 mins for a reading. Talk about a solution to a non-existent problem! Laughing
Post #524132 Fri Apr 21 2017 12:23pm
fkarim
Agreed that oil level check in the instrument panel, while accurate, is a pain. In addition to being quick, dipstick also gives you some idea about the condition of the oil. Then again, the service indictor probably takes that into account. We got way off topic with this one though Embarassed Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #524134 Fri Apr 21 2017 1:03pm
Black Bess
Yes we did. I had better stop there. Thumbs Up
Post #524135 Fri Apr 21 2017 1:07pm
