![]() | Home > General (L494) > Unauthorised Entry - Possible use of key? |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1682 ![]() ![]() ![]() |
Can't answer the questions, but should add that it's always best to lock by touch and not the remote (which can be snooped/blocked). |
Netsters Member Since: 07 Nov 2011 Location: London Posts: 175 ![]() ![]() |
Good point, i can't remember but does the touch double lock as standard? Range Rover Sport SVR - Santorini Black
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
On my MY15 I have to touch the door knob twice (rapidly) to double lock. Would be good if I could change it to one tap, as it can be difficult to tap twice quickly enough. |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
I have no problem with the double touch, there is plenty of time to do it and you can see immediately if you have by watching the indicators light flash after the second tap. After the first tap the mirrors fold up. If Tyne door isn't locked then you won't het any flashes but you should get the fault / door not closed diffent pitch, rapid double beep. I now never use the key fob buttons other than to open the tailgate if I have to get into the boot.
Thanks guys, fortunately on this occasion there was no damage, other than the couple of items taken. I actually hope that is it a case of my forgetting to lock the car up after getting in the house as that is easily remedied as opposed to someone having a way into the car.
Nesters you have a PM! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
If you closed the car but did not lock it and then after a short while someone went to open the door without key the alarm would still go off would it not? This happens on my 11mdl.
ME13OSE Member Since: 14 Jan 2017 Location: Scotland Posts: 1 ![]() ![]() |
Hi guys, first post. I pick up my first RRS in a few days, buying off a friend so not new, but new to me. I've been looking into some of the issues with these vehicles to do with security etc and it seems that there is a hand held amplifier that can be used to fool the vehicle into thinking that the key, which is safely tucked away in your house is actually right next to the vehicle. This doesn't work like a master key so if your keys are miles away then they can't mimic the key, but as most peoples keys are only yards away from the cars then basically this device picks up on the signal and makes it louder, they touch the car and it unlocks.
Welcome and looking forward to seeing some photos.
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
My keys are kept in a metal box when not in use, just in case! MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
