![]() | Home > General (L494) > Windscreen Smear |
kljw Member Since: 01 Aug 2006 Location: Edinburgh Posts: 117 ![]() ![]() |
Hi
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586 ![]() ![]() |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 ![]() ![]() |
I tried Bosch Twin Blades..seemed to work but after a couple of weeks got the dreaded smear again!
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 ![]() ![]() |
http://www.rrsport.co.uk/forum/topic39886.html
Having just had a new windscreen fitted I also replaced the wiper blades that were nearly 2 years old - I bought them from my local dealership and have been impressed with no smearing and also no rumbling when the auto-on thinks I have a wet screen when it is quite dry! Problem now for me is how to replace the rear blade because try as I might I cannot get the rear wiper to park anywhere other than in the normal parked position............... which is darned hard to get at. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
The only way I found to replace the rear wiper blade was to undo the nut on the spindle to allow the arm to drop down. You have to give it a tug to break the grip on the taper. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Chaps,
I'd forgotten how to fo that, lol. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
Did you fit longer than OEM spec to get a wider wipe at the passenger side? There's an odd unwiped spot right n front of the passenger on mine. ... 2022 P440e AB |
No just the standard sizes.[/quote] |
Hi
