Home > General (L494) > On My Third Set Of Wipers! |
What are you cleaning the windscreen with? What screenwash are you using? Just wondering if these are having an effect on your wipers. |
Sat Apr 04 2015 5:15pm |
Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567 |
Just regular car wash shampoo.... Glass cleaner afterwards, nothing exciting really.
Sat Apr 04 2015 5:22pm |
Are you replacing the wipers with OEM wipers? |
Sat Apr 04 2015 5:47pm |
Yeah from duckworths WINNER - 2009 Best in Class Range Rover Sport Award
Sat Apr 04 2015 5:48pm |
Hmm, have a word with your dealer then. I can only think there is something on your screen causing a resistance of the wiper. |
Sat Apr 04 2015 6:12pm |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 |
There's obviously a problem there. My wipers are still the originals and still clean the screen perfectly! Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Sat Apr 04 2015 9:46pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
This article appeared in today's Sunday Times...might help!
Sun Apr 05 2015 8:55am |
I once had a car (a white Rover "Tomcat" Coupe) attacked with a permanent marker pen and the only thing that would remove the ink damage from the glass areas was White Spirit, it also removed all sorts of other dirt ingrained into the glass! Take a good quality cloth (NOT a yellow duster though) and a small bottle of white spirit. Apply a small amount of white spirit to the cloth and rub into the windscreen, testing a small area first. Do the entire screen and then rinse off with HAND HOT water (not fresh boiled though as you will crack the screen!) with either a small amount of Vinegar or fresh squeezed lemon juice in it and applied by a cloth too. Dry off with a couple of sheets of newspaper then apply a proprietory glass polish. While cleaning the screen make sure the wipers are lifted off the glass and clean the wiper blades with the Vinegar/lemon juice solution (don't use white spirit on them). Do NOT spray white spirit on the glass as it can damage painted surfaces near to the screen and only use a small amount on the cloth, renewing it frequently. Also don't use Turps as a substitute for the white spirit as it doesn't work! Another good de-greaser if you know it is a grease/oily spot is Swarfega gently rubbed into the greasy area, but make sure it is the green, grit free Swarfega and not one of the ones with fine grit/ plastic beads in it! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Apr 05 2015 9:45am |
p29926 Member Since: 14 Aug 2014 Location: Leeds Posts: 1 |
I have this problem too on my 2014 RRS. Dealer have swapped the blade and then the arm but the problem is still there. Clearly a design fault |
Wed Jun 24 2015 2:28pm |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 323 |
+1, the wipers on my car working perfectly. L494 MY15, 12.000 miles city and highway ride since January, 2.000 miles offread.
Wed Jun 24 2015 4:31pm |
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 |
Maybe but I also get this on my 63-plate MY14 so perhaps it was something on early cars. With me the bottom end of the driver's blade leaves a smear that I have to peer around. Having a new windscreen tomorrow so will also change the blade and see if it makes a difference, |
Wed Jun 24 2015 5:15pm |
Mines an early-ish car (March 2014) but I can't say I've ever noticed a problem. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Wed Jun 24 2015 8:36pm |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 184 |
I've had exactly the same problem. Have changed the wipers once which made little difference. Have tried all sorts of things to clean the windscreen with no luck. Last service dealer used a Landrover product that made it a little bit better. Only smears on drivers side in line of sight. I think its the windscreen itself. Not exactly dangerous but really distracting when driving in rain. The smear is where the passenger side wiper is at the extreme end of its arc. Leaves a blur for a couple of wipes when raining.
Sat Jun 27 2015 2:10am |
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 |
Had this smear problem from new ( over 2 years) and tried all the suggestions on this site to remove problem. Just changed the wipers for a set of Bosch Aerotwins and problem has virtually gone immediately. IMO a much better blade for half the price of OEM. |
Tue Jun 28 2016 2:49pm |
