![]() | Home > General > Upgraded High Output Alternator |
No, it just takes time for the battery to charge. There's power available, but nothing can get around the time issue of short journeys. It's like chargers - a bigger charger can charge a bigger battery, but it won't charge a smaller battery faster because the battery isn't designed to do such. |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 421 ![]() ![]() ![]() |
Once the car is started it should be running off power generated by the alternator not the battery (I assume as this is the traditional way alternators work).
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Hi, just thought I might be able to help with this one.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5118 ![]() ![]() ![]() |
A bigger alternator won't help, unless your short trips involve having the climate control on Max. or loads of heaters on.
