| RRSPORT.CO.UK | ||
|  | Home > General > Thinkware speed display |
| Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200      | Usually something in the setup menu to add time & date, and speed stamp to the video file. Does the speed display if you use the Thinkware player software? If not, then could be your GPS not getting a fix... | ||
|  Sat Aug 27 2016 11:37am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | If you pull up the PC Viewer and click on settings then dashcam settings, go to far right system settings and in drop down menu, go to bottom just below time-zone and make sure speed stamp is enabled that could be your problem.
|  Sat Aug 27 2016 12:04pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Ok thanks guys,,ill check the settings when i get home in front of computer Col.
|  Sat Aug 27 2016 12:15pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | I'm on the comp now & it already says speed stamp enabled.also the time is a hour behind & it's set to London time.
|  Sat Aug 27 2016 3:01pm |
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254      | Sounds like the time zone is set to GMT but you need BST. | ||
|  Sat Aug 27 2016 3:19pm |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644    | As said - you can use app on phone to change settings too I think  | ||
|  Sat Aug 27 2016 5:16pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | My time zone is set to UTC+00.00 Edinburgh, London Etc. plus daylight saving enabled in same menu. Not to sure about the speed setting then, but mine does tell you when GPS locked on, is the green light flashing on illuminated continually?
|  Sat Aug 27 2016 5:55pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Col,should it be flashing or still.
|  Sun Aug 28 2016 8:05am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Hi Andy,
|  Sun Aug 28 2016 8:46am |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | I think it must be something to do with windscreen or where ive mounted it,ive tried reseting gps but nothing happens & its just flashing all the time.Thanks anyway Col,ill try it mounted in a dif place.
|  Sun Aug 28 2016 9:39am |
|  Sun Aug 28 2016 9:40am |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Well I think I've sorted the gps signal out,I put the camera out of the window so it connected & now it seems to be connecting ok but now when I go to watch a video on Fone it's coming up with (insufficient memory,,retry after deleting videos to free up memory) even though I've deleted most & just left 2 on
|  Sun Aug 28 2016 12:10pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Im not sure if it's the fones memory it means as it let me download 2 vids on the iPad without problems.
|  Sun Aug 28 2016 1:52pm |
| Bigbore Member Since: 08 Jun 2016 Location: Poole,Dorset Posts: 47      |
 Is that not blocking the auto dim rear view mirror sensor? RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's | ||
|  Mon Aug 29 2016 4:18am |
| Posting Rules
