Home > General > Thinkware speed display
Tyrefitter
When I'm playing the videos back its not displaying the speed..does anyone else have same problem or I got something wrong in settings.?
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #503794 Sat Aug 27 2016 12:07pm
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Usually something in the setup menu to add time & date, and speed stamp to the video file. Does the speed display if you use the Thinkware player software? If not, then could be your GPS not getting a fix...
Post #503795 Sat Aug 27 2016 12:37pm
If you pull up the PC Viewer and click on settings then dashcam settings, go to far right system settings and in drop down menu, go to bottom just below time-zone and make sure speed stamp is enabled that could be your problem.
Post #503802 Sat Aug 27 2016 1:04pm
Tyrefitter
Ok thanks guys,,ill check the settings when i get home in front of computer Col.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #503805 Sat Aug 27 2016 1:15pm
Tyrefitter
I'm on the comp now & it already says speed stamp enabled.also the time is a hour behind & it's set to London time.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #503812 Sat Aug 27 2016 4:01pm
HemoRRS
Sounds like the time zone is set to GMT but you need BST.
Post #503813 Sat Aug 27 2016 4:19pm
muddywheels
Milk Float Man
As said - you can use app on phone to change settings too I think Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #503821 Sat Aug 27 2016 6:16pm
My time zone is set to UTC+00.00 Edinburgh, London Etc. plus daylight saving enabled in same menu. Not to sure about the speed setting then, but mine does tell you when GPS locked on, is the green light flashing on illuminated continually?
Post #503822 Sat Aug 27 2016 6:55pm
Tyrefitter
Col,should it be flashing or still.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #503837 Sun Aug 28 2016 9:05am
Hi Andy,
When its locked on it should be permanent green light not flashing, if you use the phone app to access settings you can reset the GPS whether that may help not sure. I think it has been mentioned here about something to do with the RRS 2 windscreen being coated or something like that, it does mention in Thinkware manual about certain types of screen affecting GPS signal.
Post #503844 Sun Aug 28 2016 9:46am
Tyrefitter
I think it must be something to do with windscreen or where ive mounted it,ive tried reseting gps but nothing happens & its just flashing all the time.Thanks anyway Col,ill try it mounted in a dif place.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #503849 Sun Aug 28 2016 10:39am
Tyrefitter
This is where it is now
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #503850 Sun Aug 28 2016 10:40am
Tyrefitter
Well I think I've sorted the gps signal out,I put the camera out of the window so it connected & now it seems to be connecting ok but now when I go to watch a video on Fone it's coming up with (insufficient memory,,retry after deleting videos to free up memory) even though I've deleted most & just left 2 on
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #503859 Sun Aug 28 2016 1:10pm
Tyrefitter
Im not sure if it's the fones memory it means as it let me download 2 vids on the iPad without problems.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #503867 Sun Aug 28 2016 2:52pm
Bigbore
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
Andy
Is that not blocking the auto dim rear view mirror sensor? RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's
Post #503932 Mon Aug 29 2016 5:18am
