![]() | Home > General > Thinkware speed display |
| Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200
Usually something in the setup menu to add time & date, and speed stamp to the video file. Does the speed display if you use the Thinkware player software? If not, then could be your GPS not getting a fix... |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
If you pull up the PC Viewer and click on settings then dashcam settings, go to far right system settings and in drop down menu, go to bottom just below time-zone and make sure speed stamp is enabled that could be your problem.
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Ok thanks guys,,ill check the settings when i get home in front of computer Col.
I'm on the comp now & it already says speed stamp enabled.also the time is a hour behind & it's set to London time.
| HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254
Sounds like the time zone is set to GMT but you need BST. |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644
As said - you can use app on phone to change settings too I think |
My time zone is set to UTC+00.00 Edinburgh, London Etc. plus daylight saving enabled in same menu. Not to sure about the speed setting then, but mine does tell you when GPS locked on, is the green light flashing on illuminated continually?
Col,should it be flashing or still.
Hi Andy,
I think it must be something to do with windscreen or where ive mounted it,ive tried reseting gps but nothing happens & its just flashing all the time.Thanks anyway Col,ill try it mounted in a dif place.
Well I think I've sorted the gps signal out,I put the camera out of the window so it connected & now it seems to be connecting ok but now when I go to watch a video on Fone it's coming up with (insufficient memory,,retry after deleting videos to free up memory) even though I've deleted most & just left 2 on
Im not sure if it's the fones memory it means as it let me download 2 vids on the iPad without problems.
| Bigbore Member Since: 08 Jun 2016 Location: Poole,Dorset Posts: 47
Is that not blocking the auto dim rear view mirror sensor? RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's |
| All times are GMT |
