![]() | Home > Technical > Heated front seat |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Did you clear the codes after fitting new parts? MY11 Autobiography supercharged. Santorini Black. Monaco interior. Rear screens. Privacy.
dave421 Member Since: 01 Nov 2015 Location: Spalding Posts: 26 ![]() ![]() ![]() |
Hi
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
The codes are incomplete. LR codes will have two further numbers at the end. One common theme within the codes is short to ground. Also, all of those items are run through the temperature control unit. The rear seats aren't as far as I can tell, strangely. Maybe a fault in that unit. 2012 SDV6 - it's missing a couple of cylinders
HI
