| RRSPORT.CO.UK | ||
|  | Home > Technical > Brake Light Switch Question |
| savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154    |
 Is it possible for the brake light switch if faulty to cause the transmission to lose drive, this vehicle has loss power around 13 times over the last 6 weeks, when I pull over the engine is still running and revs up ok, but no drive when I put in gear, Transmission/engine failure on the message centre plus the warning lights, switch of restart engine everything is fine for a few days and problems again, parts replaced by dealer, battery, egr valves, low pressure fuel pump, fuel filter, they cannot seam to cure the fault, the brake is not pressed when the power is lost, looking on the forum problems may arise when brake pedal pressed and the warning messages show up, that's when the switch is fault I think, any ideas anyone, please read my other post on this, Cheers  | ||
|  Tue Dec 08 2015 9:17pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | It is an inexpensive and simple job to replace the brake pedal switch so worth doing just as preventative maintenance. Here is a link to an attempt at a guide on how to do it:
|  Tue Dec 08 2015 9:59pm |
| savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154    | Starting to think now it may be the Tekonsha P3 brake controller causing the problems, supposed to be plug and play with the plug in wiring harness near the brake pedal its a gray connector plug which is meant to be factory fitted but there is not one there, so got auto electrian to fit it, but because of the sensitive electronics on these this could be the problem, what do you think guys, | ||
|  Wed Dec 09 2015 5:50pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | Yes, I would say that has to be the first port of call.  | ||
|  Wed Dec 09 2015 5:54pm |
 [quote="savi18"]Is it possible for the brake light switch if faulty to cause the transmission to lose drive, this vehicle has loss power around 13 times over the last 6 weeks, when I pull over the engine is still running and revs up ok, but no drive when I put in gear, Transmission/engine failure on the message centre plus the warning lights, switch of restart engine everything is fine for a few days and problems again, parts replaced by dealer, battery, egr valves, low pressure fuel pump, fuel filter, they cannot seam to cure the fault, the brake is not pressed when the power is lost, looking on the forum problems may arise when brake pedal pressed and the warning messages show up, that's when the switch is fault I think, any ideas anyone, please read my other post on this, Cheers  | ||
|  Sat Dec 12 2015 8:20pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | So did it fix the problem or not?
|  Sun Jan 03 2016 5:40pm |
| savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154    | Well the sport ran great for 2 weeks and 1000 miles and  thought the problem was fixed but no. 3days left to go away in caravan and dam thing lost transmission powe5 timesr over the last 3 days coming up with same faults as original posted .so at a loss now to want the problem is.
|  Sun Jan 03 2016 9:31pm |
|  Sun Jan 03 2016 9:33pm |
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477    | You need to get a complete list of faults from a LR capable diagnostic tool (dealer, indy, whatever).  | ||
|  Mon Jan 04 2016 9:57am |
| Posting Rules
