Home > General > Yellow triangle with exclamation mark. RRS 2012
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Can anyone tell me the meaning of the above warning light, I have had a look in the manual but it is not there.
I was out today and it came on, turned the car of and back on and it cleared for a while but did come back, did the same again and the last time it stayed off till I got home.
There are no messages in the information screen when it is on. Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #475378 Mon Oct 05 2015 5:38pm
I thought the Amber Triangle was a non critical warning message, if it's not showing the message in the Drivers Information Centre It may be that you will have to have the codes read through diag. port
Post #475379 Mon Oct 05 2015 5:50pm
Frax
I know it is a none critical warning but it may lead to one so thought I had best check.
I do not like any warning light as all and if it need looked at I will get it done before they get worse.
Just hope its not a bad one Confused Lot of Landcruisers now sold
Defender 300tdi 90
Post #475380 Mon Oct 05 2015 5:58pm
Have you gone into the menu and searched warnings? It should come up in there.
Post #475381 Mon Oct 05 2015 6:13pm
Frax
Will have to have a look, will it hold it even though it has cleared now Ady 555.
It did this once before months ago and the car was parked but ticking over. Lot of Landcruisers now sold
Defender 300tdi 90
Post #475385 Mon Oct 05 2015 6:29pm
It might be your DPF that is full if you do a lot of stop/start journeys. It will clear itself after a short blast down the motorway. It might still be registered in your warnings menu.
Post #475386 Mon Oct 05 2015 6:54pm
Frax
Went out and checked the menu and it did come up as a suspension fault, the car would not lower or rise when asked to.
The alarm would not clear with the OK button but did after turning it of and back on and the suspension did as asked after that.
Once again the car was parked and not moving with suspension set at normal driving hight which it holds for weeks with no drop. Lot of Landcruisers now sold
Defender 300tdi 90
Post #475389 Mon Oct 05 2015 6:58pm
Frax
Hi Ady 555 - that was changed about a month ago when it went to restricted performance. Lot of Landcruisers now sold
Defender 300tdi 90
Post #475390 Mon Oct 05 2015 6:59pm
Tim in Scotland
If you scroll the nav screen to the 4x4 info have a look and see if you have a red bar at any of the ride height sensors, one of them may be on the way out or have a loose connection 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #475391 Mon Oct 05 2015 7:00pm
Frax
Hi Tim
Tried that but all looked well, may need to do it again and change the hight at the same time. Lot of Landcruisers now sold
Defender 300tdi 90
Post #475393 Mon Oct 05 2015 7:02pm
rigsby
Washer fluid level low always put my amber light on, it was the only warning light I ever had Thumbs Up Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #475395 Mon Oct 05 2015 7:04pm
Frax
Worth a go I suppose Confused Lot of Landcruisers now sold
Defender 300tdi 90
Post #475397 Mon Oct 05 2015 7:06pm
rigsby
Could be the cheapest fix ever Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #475414 Mon Oct 05 2015 8:42pm
Frax
You must be one lucky boy never having a warning worse than water level Bow down Lot of Landcruisers now sold
Defender 300tdi 90
Post #475426 Mon Oct 05 2015 10:43pm
Frax
Was at the garage today which is about 40 miles from me and had the RRS scanned.
On the drive there it came in 3 times Big Cry but I had a few things to do before the scan, each time I turned the key off and back on the alarm cleared.
After I had the RRS scaned I was told that it was a minor fault and they had cleard it. They had taken it for a good drive and it did not come back in. I was told if it did come back in they would have a better look but to try it for now.
So on the way home I did quite a long drive (over 60 miles on all the windy roads I could think of and I have to say the alrm never came back.
I know a scan wont fix it but things are good for now and hope they stay that way Thumbs Up Lot of Landcruisers now sold
Defender 300tdi 90
Post #475855 Fri Oct 09 2015 5:18pm
