![]() | Home > General > Yellow triangle with exclamation mark. RRS 2012 |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 242 ![]() ![]() ![]() |
Can anyone tell me the meaning of the above warning light, I have had a look in the manual but it is not there.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5096 ![]() ![]() ![]() |
I thought the Amber Triangle was a non critical warning message, if it's not showing the message in the Drivers Information Centre It may be that you will have to have the codes read through diag. port
I know it is a none critical warning but it may lead to one so thought I had best check.
Have you gone into the menu and searched warnings? It should come up in there. |
Will have to have a look, will it hold it even though it has cleared now Ady 555.
Went out and checked the menu and it did come up as a suspension fault, the car would not lower or rise when asked to.
Hi Ady 555 - that was changed about a month ago when it went to restricted performance. Lot of Landcruisers now sold Audi TT 240 Sport now sold for. RRS 2.7 HSE Now sold for. RRS Autoibiography 2012 Defender 300tdi 90 |
If you scroll the nav screen to the 4x4 info have a look and see if you have a red bar at any of the ride height sensors, one of them may be on the way out or have a loose connection 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Hi Tim
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Washer fluid level low always put my amber light on, it was the only warning light I ever had |
Worth a go I suppose |
Could be the cheapest fix ever |
You must be one lucky boy never having a warning worse than water level |
Was at the garage today which is about 40 miles from me and had the RRS scanned.
