![]() | Home > General > Help Stuck in France |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2019 ![]() ![]() |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 ![]() ![]() ![]() |
One of the reasons I did not go for LR Warranty/Assistance is that they only cover a trip up to 30 days. Lots of LR customers wish to use their vehicles much more than that in Europe more so than ever with the integration of Europe. See below - 'Validity (Europe only) Land Rover Assistance is only available in Europe for travel not exceeding 30 days duration in a single trip and 91 days duration in any 12 month period. It is recommended that adequate travel insurance is taken out in addition to this cover.' Warranty Direct state as follows: 'Overseas Use This policy covers repairs carried out in Great Britain and Northern Ireland. If you use your vehicle overseas for less than 100 days a year this policy also covers repairs carried out in Europe. You must get the administrator’s authorisation before any repair work is started. You will have to pay the repairer and claim back the cost from us.' Hence why I went for Warranty Direct. Although when I first informed WD I had a problem their first statement was as they could not speak French I would have to repatriate the vehicle at my cost back to the UK for inspection. If they hold this position then I will raise this as a complaint. I would certainly like to know what other LR drivers do who drive in Europe more than a month but less than 90/100 days. |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Not sugesting your Stupid. But my first move would be get it out of drive. It seems when landrovers have one problem , it triggers many other problems. As when a brake light switch goes down,it shows many other warnings that things are not working correctly. Thats landrover for you. try to keep you in the dark,so you have to go to main dealers. itisme |
Sorted it? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Update - Tuesday 30th June.
I'd stick with it for a while longer as you've spent that much already.....
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Glad that you are now heading in the right direction and WD is coughing up! I think you have had some pretty warm temps in La Rochelle! I recently returned from Noirmoutiers before it heated up.
Not been down any toll roads where tag readers would be in the last three weeks. However, you are quite correct the day I parked the car it was very hot and when we came back three hours later the alarm was going off. Obviously some
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Thermal expansion of circuit board could have caused bad joint or connection - hence the issue. Probability of that happening goes up with the number of thermal cycles. I just had similar failure on my daughters mercedes w204 - so it is not just a jlr issue - similar cost to fix as well - Id blame on global warming or just more complex electronics in cars these days ! Btw , toyota has some of the most stringent specs and tests in the industry for this sort of thing - so I think the only way to minimize those sort of issues is to get a land cruiser ! Bmw or Mercedes would be just as bad .... |
very frustrating indeed. It does seem though that talking to WD and others in the Motor Trade they all love the RRS for driveability, comfort and all the other things we love about the cars but then they say "Except Reliability" to me that is an awful reputation to have. |
Cant understand how the dignostics takes 3.1 hours. I thought as soon as it is plugged in it comes up with all the fault codes? Did it have so many it took 3.1 hours to read them all? Lucky it wasn't Stratstones doing the job,their labour is £150 + vat an Hour. Thats £558 for diognostics ![]() |
Fault codes are quick, but there are other sides to diagnostics that are more complex/time consuming. Fully diagnosing and attempting to recover a corrupted ECU is not such a simple process and, as is evident, the results can cause all sorts of symptoms which can be misleading. If the BCM is dead/the software crashes, it won't communicate with the diagnostic tool in the first place. |
Update Wednesday 8th July.phoned Land Rover La Rochelle to enquire if car was ready and quote they said they were talking to LR UK as there was some issue in requiring an electronic key module in order that the key would talk to the new electrical ECU they have fitted. They say that we must reclaim that part from LR UK. Firstly we don't understand why this was not mentioned in the quite we originally got and Warranty Direct signed off on. secondly we do not understand why we then have to claim that part back off LR UK.
Would like technical input if anyone can explain this please.
