Home > Technical > Recent Turbo Issues
Simo1976
Recent Turbo Issues
Hi Guys,
After some advice if poss, my TDV6 RRS has recently been suffering with the dreaded "limp mode" fault and after various resets and checks we decided to have the turbo replaced. We collected the car yesterday and I drove it home. Power delivery top end seems a lot better but the car is hesitant to change down gear when I "stick the boot down" - when it does change down there still seems to be lots of smoke generated (more than what I would consider to be the norm) and the response at lower speeds generally seems very sluggish. It has been re-mapped EGR's blanked, and just does not seem as good as it was when we first had these carried out.
Should we be looking at anything else? Is it worth getting the gearbox flushed? Any suggestions most welcome. Out and About
Post #463659 Wed Jun 03 2015 11:30am
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
I have similar symptoms but I haven't replaced the turbo.
I'm having a gearbox flush and a hard reset which I hope will resolve the gear change issues.
I find I get my black smoke at 3000rpm. I have had a re-map which apparently increases the smoke, but I feel there's more than there should be. 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #464345 Thu Jun 11 2015 8:54pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Iv'e heard that black smoke is a turbo problem,and if not sorted quickly could lead to engine seizure Big Cry itisme
Post #464366 Fri Jun 12 2015 9:02am
Disco_Mikey
Black smoke is overfuelling, be it too much fuel, or not enough air.
A remap will cause a little extra smoke, but it should not be excessive
Post #464368 Fri Jun 12 2015 9:05am
Lost for Words
Can be, but there are plenty of other causes such as a split turbo hose, leaking intercooler, faulty MAF meter, injector issues, and of course, the old favourite - EGRs. Wink Visiting from DISCO3.CO.UK
Post #464370 Fri Jun 12 2015 9:08am
Simo1976
Thanks guys. Will have to get it booked into the local garage for them to check again. Out and About
Post #464372 Fri Jun 12 2015 9:24am
darrenmcneill
• Turbo Hose replaced (Left Hand side) with silicone hose. Haven't attempted the R/H side yet as that looked a bit more fiddly!
• MAF was replaced end of last year
• EGR's blanked end of last year.
Im presuming then that I'd be looking at over fuelling, which is pointing to a crappy re-map? 2006 HSE for Sale - £7,499 (Manchester)
Post #464378 Fri Jun 12 2015 10:26am
Lost for Words
I'm assuming you're referring to that as looking at the front of the vehicle (Left and right hand sides are normally referred to as in the direction of travel)? Question
Possibly, but I'd still be doing some further investiagtion (the other two turbo hoses, intercooler, turbo/turbo actuator, injector values etc.) before concluding that, unless you have particular reason to be suspicious of the map? Visiting from DISCO3.CO.UK
Post #464380 Fri Jun 12 2015 11:08am
Simo1976
I have not had any of the hoses looked at, the exchange turbo has gotten rid of the "limp home" issue, although today was particularly bad, if rolling up to a roundabout or junction and don't quite stop put the foot down to keep going and it seems to be an age for anything to happen then it picks up and kicks a cloud of black smoke out of the back... And seems to be getting worse..! Out and About
Post #464420 Fri Jun 12 2015 10:20pm
robbo770
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Buy some silicone intercooler hoses!!
Try following a simple guide Thumbs Up
http://www.disco3.co.uk/forum/topic94971.html None currently
Gone
rejected RRS autobi Dynamic MY14.5 (Peter Vardy 👎)
D3 XXV full conversion
4.2 SC FFRR
4.4 FFRR
Freelander 1
Post #464431 Sat Jun 13 2015 9:47am
Simo1976
I think I will just bite the bullet and change the hoses, looks simple enough Thumbs Up Out and About
Post #464538 Sun Jun 14 2015 6:52pm
Simo1976
What a bloody job this is.. first 2 hoses no trouble, small hose pain in the fCensoredg Ar Censored e
3 hours fiddling about.. All done now Out and About
Post #465110 Fri Jun 19 2015 2:48pm
Simo1976
Hi guys, I still seem to be having the same "low end" power loss and smoke issues. Any suggestions? Maybe the dreaded crossover pipe? Any suggestions most welcome.
Thanks in advance. Out and About
Post #465433 Tue Jun 23 2015 6:33am
Disco_Mikey
I'd be looking at EGR issues before the crossover pipe Thumbs Up
Post #465435 Tue Jun 23 2015 7:18am
Simo1976
Hi Disco_Mikey,
EGR's have been blanked? Out and About
Post #465437 Tue Jun 23 2015 7:26am
