![]() | Home > Technical > Recent Turbo Issues |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
I have similar symptoms but I haven't replaced the turbo.
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Iv'e heard that black smoke is a turbo problem,and if not sorted quickly could lead to engine seizure |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
Black smoke is overfuelling, be it too much fuel, or not enough air.
Can be, but there are plenty of other causes such as a split turbo hose, leaking intercooler, faulty MAF meter, injector issues, and of course, the old favourite - EGRs. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Simo1976 Member Since: 18 Sep 2014 Location: Kent Posts: 25 ![]() ![]() ![]() |
Thanks guys. Will have to get it booked into the local garage for them to check again. Out and About |
• Turbo Hose replaced (Left Hand side) with silicone hose. Haven't attempted the R/H side yet as that looked a bit more fiddly! • MAF was replaced end of last year • EGR's blanked end of last year. Im presuming then that I'd be looking at over fuelling, which is pointing to a crappy re-map? 2006 HSE for Sale - £7,499 (Manchester) http://www.rrsport.co.uk/forum/topic46383.html |
I'm assuming you're referring to that as looking at the front of the vehicle (Left and right hand sides are normally referred to as in the direction of travel)? ![]()
Possibly, but I'd still be doing some further investiagtion (the other two turbo hoses, intercooler, turbo/turbo actuator, injector values etc.) before concluding that, unless you have particular reason to be suspicious of the map? Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
I have not had any of the hoses looked at, the exchange turbo has gotten rid of the "limp home" issue, although today was particularly bad, if rolling up to a roundabout or junction and don't quite stop put the foot down to keep going and it seems to be an age for anything to happen then it picks up and kicks a cloud of black smoke out of the back... And seems to be getting worse..! Out and About |
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 ![]() ![]() ![]() |
Buy some silicone intercooler hoses!!
I think I will just bite the bullet and change the hoses, looks simple enough |
What a bloody job this is.. first 2 hoses no trouble, small hose pain in the f |
Hi guys, I still seem to be having the same "low end" power loss and smoke issues. Any suggestions? Maybe the dreaded crossover pipe? Any suggestions most welcome.
I'd be looking at EGR issues before the crossover pipe |
Hi Disco_Mikey,
