Home > Technical > Recent Turbo Issues
Disco_Mikey
Missed that part Embarassed
Time to start checking live data and fuel pressures Thumbs Up
Post #465447 Tue Jun 23 2015 9:55am
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Simo1976 wrote:
Hi guys, I still seem to be having the same "low end" power loss and smoke issues. Any suggestions? Maybe the dreaded crossover pipe? Any suggestions most welcome.
Thanks in advance.
What Rev range is the smoke issue at? I'm following this as I have the same issues, but don't want to hijack the post or duplicate it again with my own issues.
Mine occur at 3000rpm+, and I find it's worse when in normal driving mode than in sport mode. Travelling at 80-90 with Revs over 3000 isn't an issue, it's the build up to the speed going through the gears.
I like yourself have had the EGR's blanked, and I also have a new MAF unit. 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #465480 Tue Jun 23 2015 3:11pm
Simo1976
The problem for me is at the lower end, rolling up to junctions and pulling away, it seems to take an age to pick up then does with a bit of clout and I am leaving my fellow road users in a cloud of thick black smog... Smoke isn't a problem normal driving just the lower end of the Rev counter. Becoming bloody painful.. Out and About
Post #465491 Tue Jun 23 2015 6:54pm
darrenmcneill
I have a similar delay at the low end, both a bit of a surge, but not as dramatic as yours it seems. I did a "soft gearbox reset" a few months back which seemed to cure it for a while, but it's gradually getting worse.
I'm getting a flush & hard reset from Mike in July so it should fix that issue for myself. Have you had the flush & reset? 2006 HSE for Sale - £7,499 (Manchester)
Post #465492 Tue Jun 23 2015 7:26pm
Simo1976
Not had the flush or reset.. been trying to sort that... think thats the next job...!!! Out and About
Post #465592 Wed Jun 24 2015 6:16pm
