![]() | Home > Technical > EPB Strange Problem |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Great - its a lesson that some times, faults are faults!! Mike
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
Agreed! 2008 TDV8 - it was a labour of love and is much missed |
| DaleKit Member Since: 11 Feb 2015 Location: West Yorkshire Posts: 1
Hi Mat,
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139
Hi Dale,
| Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380
Well done that man ! , I believe that somewhere on here there are a few posts and problems that often mention this plug, and it has been removed and soldered just like you have done with the wire |
| gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63
It is green status lamp wire from parking brake module PBM to instrument cluster IPC
| CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174
Excellent, I've bee watching this thread. Funnily, I was thinking of mentioning that connector and associated wiring, as when I was rummaging around the rear of mine, I noticed that the plastic clamp to the chassis had broken, and it was able to move around. I used some tie-wraps to secure it as a temporary measure. |
| Autodoc Member Since: 25 Mar 2020 Location: TN Posts: 3
What area are you talking about driver or pass side wheel arch |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
I assume you mean what is n/s/r which is Near Side Rear, which in your case being L/H/D will be the left hand (drivers side) rear fender wheel well.
Thanks for the update!! Just never heard nsr before |
I have the code c1a48 I hope I can find the issue with the wires . The parking brake works and holds and releases, tried clearing the code but it won’t clear . I can hear the actuators working . Is there anything else I should be checking for? |
| All times are GMT |
